RV.Net Open Roads Forum: Fifth-Wheels: Fantastic fan ???
 > Fantastic fan ???
ilvtravln
Calif.
Posted: 10/22/11 01:21pm Link  |  Print  |  Notify Moderator
My fantastic fan seems to have a mind of its own. It goes up and down at will. I know there is a rain sensor attached to it, there has been little rain here yet this season but there is some morning dew here. Often the lid goes up and down in the afternoon when it should be completely dry, any ideas what I might do ? Thanks
Art
deereone
NE
Posted: 10/22/11 01:30pm Link  |  Print  |  Notify Moderator
Mine did that at one time. I went up on the roof and cleaned the rain sensor strip. It worked good after. It's a easy try.
rv2go
Fulltime (Knoxville, TN).... or someplace else
Posted: 10/22/11 01:32pm Link  |  Print  |  Notify Moderator
That is strange. I would give Fantastic fan a call. The service rep will tell you what's needed and send it to you free. Great service from them.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
Traveler II
Minnesota
Posted: 10/22/11 01:54pm Link  |  Print  |  Notify Moderator
On our last rig we had the same thing, but I cleaned off the sensor and it worked fine, it just was dirty.
2011 Cameo 34SB3
2008 Chevy D/A, Smartair Air Springs, Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2011 - 165
Nights Camped in 2012 - 142
Nights Camped in 2013 - 101
ilvtravln
Calif.
Posted: 10/22/11 02:22pm Link  |  Print  |  Notify Moderator
I will clean the rain sensor. Thanks everyone.
Golden_HVAC
Fulltime, CA, USA
Posted: 10/22/11 02:51pm Link  |  Print  |  Notify Moderator
Hi,
I have some dust on my rain sensor, and that will make the sensor conduct just like there is water on it. I think the cleaning solved your problem,
Fred.
Allworth
Orlando, FL
Posted: 10/23/11 12:06pm Link  |  Print  |  Notify Moderator
C S,
From inside the trailer; remove the knob, take the inside pannel down, cut the white wire going to the rain sensor (usually located in the curb-side rear corner of the housing), reassemble the fan.
No more rain sensor.
The M-F in my bedroom has a switch to turn the rain sensor on-off. Came that way from the factory.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
C Schomer
Buckeye, Az.
Posted: 10/23/11 10:05am Link  |  Print  |  Notify Moderator
I need to call them about the same problem. I cleaned the sensor and it still acts up. I want to defeat the sensor cuz I have a louvered cover over mine but I'd like to keep the auto open/shut, spot/limit feature. Craig
Happy Prospector
The Great Sonora Desert
Posted: 10/23/11 10:55am Link  |  Print  |  Notify Moderator
My problem was the rain sensor also, cleaned it up and now it works great.
Kevin
Kevin
Retired, Fulltime RV'er
1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler
2007 Yamaha Grizzly 700 (Green-It's your Daddy)
One Tough Kitty Named Bob
Bluefreight
east coast
Posted: 10/23/11 08:33am Link  |  Print  |  Notify Moderator
What is the thermostat set at. That will make it go up and down with a temp change.
 > Fantastic fan ???
