RV.Net Open Roads Forum: Class A Motorhomes: Coach disconnect switch
 > Coach disconnect switch
DouglasBriggs
Vassar, Michigan
Posted: 10/25/11 08:32am Link  |  Print  |  Notify Moderator
I have a 2001 Winnebago 35u that I put away for the winter. The coach disconnect switch sounds and feels like it is working but the interior lights still work and I noticed the inverter power light is still on. What all power is cut off by this switch ?
enblethen
Moses Lake, WA
Posted: 10/25/11 08:51am Link  |  Print  |  Notify Moderator
Many have the inverter wired directly to the batteries. It needs to have fuse pulled or cable disconnected.
Some inverters draw higher amperage then disconnect relays can handle.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
generalexam
usa
Posted: 10/25/11 09:33am Link  |  Print  |  Notify Moderator
remove ground cables and then your 100% off
