RV.Net Open Roads Forum: Fifth-Wheels: Northwood adds new 5th floorplans
 > Northwood adds new 5th floorplans
RVcrazy
Puyallup, WA, USA
Posted: 10/25/11 09:01am Link  |  Print  |  Notify Moderator
Those interested in Northwood (Arctic Fox etc) 5ths might want to take a look at the new plans. The website has been significantly improved also.
n7bsn
Yes
Posted: 10/25/11 09:25am Link  |  Print  |  Notify Moderator
Unfortunately they also eliminated a bunch.
The Nash line has been gutted (they already eliminated 5ers from the Nash line)
All of the small 5ers are gone, the 24-5N had it's last production run in August, now their smallest Arctic Fox is the 27-5L
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
fordsooperdooty
Posted: 10/25/11 10:55am Link  |  Print  |  Notify Moderator
Northwood Nash Website HERE!
dieselhorse
South Texas .........a whole 'nother country
Posted: 10/25/11 01:45pm Link  |  Print  |  Notify Moderator
The 23-5A and 245-N fifth wheels are now found under the new Fox Mountain brand with improvements to the floorplans and stand-up bedrooms. As an owner of a 245-N, I often wonder why anyone would make a bedroom 1' short of stand-up height.
dieselhorse: a free range animal
"Mountain Cabin" 2001 Northwood Nash 245N
2007 Dodge 2500 quad short "Lone Star" 4x4 w/5.9 CTD, 48RE
n7bsn
Yes
Posted: 10/25/11 01:58pm Link  |  Print  |  Notify Moderator
Em, not really
The FM 245RKS is over 2 ft longer then the Nash/AF 24-5N. It also is taller (you can stand up in the bedroom) and has a fraction of the closet space.
I actually owned 24-5N (a 99, until we traded it in this spring). I could have talked the DW into keeping it, if we had been able to stand in the bedroom.
A friend of mine traded his 24-5N in on the 245RKS
Similarly the FM235RLS is not the Nash/AF-23-5A, as it is almost 2 ft longer and has a completely different floor plan
tx racer 67
Greenville Tx
Posted: 10/28/11 10:53pm Link  |  Print  |  Notify Moderator
I like the new cap,look nice
03 chevy
05 cruiser
67 camaro
beachram
Delaware
Posted: 11/01/11 11:02am Link  |  Print  |  Notify Moderator
The 29-5K looks like a great floorplan. Has anyone found a complete set of specifications? They are TBA on the northwood website.
2007 Sunnybrook Sunset Creek 255RK
2004 Dodge Ram 2500 4x4 Diesel
Equalizer Hitch
Prodigy Brake Controller
mark1228
Posted: 11/03/11 02:50pm Link  |  Print  |  Notify Moderator
They have not built the prototype of the 29-5K yet but hope to soon and then I suspect we will see more info
beachram
Delaware
Posted: 11/04/11 09:31pm Link  |  Print  |  Notify Moderator
The only thing I would change is the bathroom by making it an enclosed room including the shower and toilet.
beachram
Delaware
Posted: 03/20/12 09:22am Link  |  Print  |  Notify Moderator
The specs are up on the northwood site for the 29-5k. The tanks are huge but that thing is really heavy for 33'.
Specifications:
Dry Axle Weight (approx. Lbs.):9220
Dry Hitch Weight (approx. Lbs.):2900
Net Carrying Capacity:4780
Gross Dry Weight - Lbs.:12120
Gross Vehicle Weight (GVWR) - Lbs.:16900
Exterior Length (approx. w / hitch):33'11"
Exterior Height (approx.):13'
Exterior Width (approx.):8'6"
Tire Size: ST235/85R16
Load Range: G
Fresh Water Capacity (approx. gal):82
Gray Water Tank (approx. gallons):72/35
Black Water Tank (approx. gallons):65
LPG Capacity (approx. lbs):20
CSA - Canadian Dealers Only:Yes
Auto Ignition Furnace (1,000 BTU's):35
