RV.Net Open Roads Forum: Toy Haulers: Tie down a vehicle in a toyhauler
Search only in Toy Haulers
 > Tie down a vehicle in a toyhauler
my996duc1
SoCal
Posted: 10/25/11 10:40am Link  |  Print  |  Notify Moderator
Just bought an Attitude FL28AKLG toyhauler and I want to put my Suzuki Samurai inside.
I have always just flat towed it when going somewhere to off-road so I don't know the proper way to tie/strap it in.
How are you guys strapping in larger vehicles...
- Are you strapping the axle OR the bumper tow points to the toyhauler anchor points ?
- How many straps are you using ?
- What kind of straps are you using (cambuckle, racket)?
I see a package of straps rated at "xxxx"lbs. Does that mean each strap is rated at the "xxxx"lbs or is it the combo of all straps together can hold "xxxx"lbs ??
Thanks !
_
* This post was edited 10/25/11 10:48am by my996duc1 *
2007 Coachmen Cross Country 354MBS
2005 LJ Rubicon Sahara
TAS
Baton Rouge, La
Posted: 10/25/11 10:49am Link  |  Print  |  Notify Moderator
straps
I use two front and two rear around the axles. The body bounces w/ the trailer and can shock load the straps if attached to the bumpers etc...
Todd
12 F-350 4x4 CC DRW
07 Dodge 2500, 4x4, CTD, 6spd (sold)
94 Harley FLSTC
98 TJ w/ a few mods
08 Fuzion 302
01 Rockwood 8292s (gone to a new home)
84 Jayco pop up (Sold but not frogotten)
BigJon05
Central Valley CA
Posted: 10/25/11 10:50am Link  |  Print  |  Notify Moderator
You want it tied down well enough so when you slam on your brakes, it doesnt jerk forward and fly through the front of the trailer. Most of my tiedowns are on the rear of whatever I am tying down, usually 2 of them on the bumper going to each side floor track. (I have e-track which i like alot better than d rings). I do tie to the front for the heavier atvs and go to the side tracks as well. I use the 2 inch wide ratchet straps from HF.
2007 3924 Raptor
03 F350 PSD longbed, 6" fabtec, BFG 35, airbags and compressor
09 Can-am Outlander 800 max xt ltd
07 Can-am Outlander 650 max xt
kemo 1
ontario canada
Posted: 10/25/11 10:56am Link  |  Print  |  Notify Moderator
Are you using D rings or E track. I am using both systems in my trailer, I want 2 independent systems in case 1 fails, last year I had a D ring open up, my Harley stayed upright but was leaning, I would cross the straps in a "X" so that the load can not move side to side.
Ken
GENECOP
NEW YORK
Posted: 10/25/11 10:59am Link  |  Print  |  Notify Moderator
I carry a Smart Car in a Toy Hauler, first I have a chock system, the front chocks put the front of the car about 1" from the garage wall, the chocks lock in and the car can't go forward, then I place a rear chock system in the back which rests against the rear ramp door. This locks the car in Front to Back, then I use ratchet straps into zbar two, directly to wheels....G
Dennis M M
Geneva, IL; Tucson, AZ
Posted: 10/25/11 11:23am Link  |  Print  |  Notify Moderator
When I carried race cars in box trailers I just put straps around the front suspension to front tie downs and straps around the rear axle to the rear tie downs.
Now that I carry a smart on my deck I use wheel bonnets, but they require tie downs ahead of and behind the wheels.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
Dirtclods
Newport Beach
Posted: 10/25/11 11:45am Link  |  Print  |  Notify Moderator
Wheel bonnets http://images.search.yahoo.com/images/vi........i=15drvplkb&sigb=11nbopnqc&fr=slv1-yff35
Doughboy12
Minnesota
Posted: 10/25/11 12:17pm Link  |  Print  |  Notify Moderator
Only you can tell, read the fine print as they say.
You WILL need to upgrade your tie-down points for a car/ORV.
Y-Guy
Tri-Cities, WA
Posted: 10/25/11 12:44pm Link  |  Print  |  Notify Moderator
Even for my ATVs I've started using the HD ratchet straps. They come in sizes from 1" to 4" so you can get ones that are rated for your needs. They will be rated with something like "Working Load Limit = 3,333 lbs" My suggestion is, don't go cheap. I chewed through several cheap 1" straps, I've had my 2" straps for 4 years now and feel much safer using them.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
mapguy
Puget Sound
Posted: 10/25/11 02:17pm Link  |  Print  |  Notify Moderator
Agree with Y-guy -don't skimp on tie down apparatus -it will cost in the long run.
Tie down hardware and straps have two ratings:
1. Ultimate strength. This is the ultimate rating per device.
2. Working Load Limit (WLL)-this is the actual every day number to use. Quality straps will be WLL rated at 1/3 or less of the ultimate strength.
Your combination of tie down points, hardware and straps are only as strong as the weakest rated piece. If using 4 wheel bonnets each wheel system must handle 1/4 of the Sammy's weight for WLL of each piece in that assembly.
Strongly suggest that any tie down points be frame attached and not floor attached for long term reliability.
I like wheel bonnet strap systems the best if tie down points are in the correct location. These allow the suspension to move without "reaction" to normal road way bumps and jolts but keeps the vehicle in one place.
