RV.Net Open Roads Forum: Tow Vehicles: Why go F450?
Search only in Tow Vehicles
 > Why go F450?
bmiller131
Ohio
Posted: 10/25/11 12:30pm Link  |  Print  |  Notify Moderator
I am in the position to purchase a new TV for my employer. I have been given free reign to pick and choose. I was leaning towards an F350 DRW, 6.7, Lariat but wondering if there is any significant advantage to going to an F450. First look tells me that the payload is actually less on the 450, plus mileage will be worse with the 4.30 gears. Anyone have a reason to go 450? Trailer is 45' gooseneck at about 17000 lbs. Thanks in advance.
2001 Ford Excursion Limited aka 'the party bus'
2011 Prime Time Lacrosse 318BHS
lawnspecialties
Garner, NC
Posted: 10/25/11 01:12pm Link  |  Print  |  Notify Moderator
If the rear axle weight doesn't exceed, I'd go with the 350; especially if there's a lot of highway towing.
Don't get me wrong, when I get on the throttle with the Cyclone behind, its amazing how well she gets up to speed. But I also think a 4.10 gear and even a 3.73 would be sufficient. My '09 F350 with the 3.73 pulled the Cyclone quite well before we traded it in.
I'm getting around 8 mpg at interstate speeds loaded down (28,000 lbs. total). I'm also getting close to 17 mpg (empty) on the 55 mph highways. But with a 4.10 or 3.73, it'd be even better.
Main reason I bought the 450 over the 350? 1. Selection: Dealer had 10 450s and two 350s. 2. I eventually plan to put an auxiliary tank in the bed and was trying to make sure the tank and heavy pinned Cyclone didn't exceed things.
2017 F450 Lariat 4X4 6.7L
2016 Vengeance Touring Edition 40D12
bmiller131
Ohio
Posted: 10/25/11 01:41pm Link  |  Print  |  Notify Moderator
Thanks for the info. From what I read off of the Ford spec page, payload is actually lower on the F450. Am I reading this right?
hawkeye-08
Northwest
Posted: 10/25/11 01:48pm Link  |  Print  |  Notify Moderator
I would not expect the mileage to be worse necessarily. If you drive in areas that are limited to 55-60mph, being in higher trans gear will offset the lower rear end (you might be in 4th with the 3.73 rear gears, but with the 4.30, you might be in 5th or 6th) I doubt that you will run out of gears in trans for top speed with the 4.30 rear.
45Ricochet
North Idaho
Posted: 10/25/11 02:10pm Link  |  Print  |  Notify Moderator
I really don't know why they made the 450 any longer. Your right looking at a spec sheet the 350 is just about the same as the 450. I don't know what Ford thinking was. Just a couple of years ago there was a noticeable difference between the two.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
mkirsch
Rochester, NY
Posted: 10/25/11 02:22pm Link  |  Print  |  Notify Moderator
You're reading it correctly.
When Ford re-did the F450 here last year the result was a truck with less payload capacity than an F350, but more towing capacity.
Capt Skup
Southern Maryland/Nantucket
Posted: 10/26/11 05:46am Link  |  Print  |  Notify Moderator
The 2011+ F450 pickup is basically what used to be called the Tow Boss option for the 350, a F-350 with 4.30 gears. I think the current F-450 would be hard pressed to tow to the GCWR without exceeding GVWR. I was at 32,250lbs GCWR and still had a few pounds under the 9500lb rating of the rear axle but not by much. Luckily the Dana 110 axle is rated at 14,500lbs and I was well under the max rating for the four 19.5 tires so I had plenty of cushion.
Capt Skup
AD-1(AW)USNRet.
Wonderful Wife,3 Daughters,2Goldens Gus&Riley
"Never get in a battle of wits with an unarmed man"
F-450 Lariat 4x4
Honda Odyssey EX-L
SunlineF281SR
SeaRay 240 Sundeck
http://community.webshots.com/user/CaptSkup?vhost=community
bmiller131
Ohio
Posted: 10/26/11 05:49am Link  |  Print  |  Notify Moderator
What year is your truck? If you have 19.5 tires then I assume it is pre-2011 or chassis cab.
Capt Skup
Posted: 10/26/11 07:21am Link  |  Print  |  Notify Moderator
2008 F-450. I suspect, not only for less weight to gain some MPG, the other reason for dropping the Dana110 axle was torque limits of the axle. I read on Dana's website that the 110 and 130 axle are limimited to 600lbs of input torque, maybe why the cab chassis 6.7 is derated.
45 ACP
Posted: 10/26/11 11:00am Link  |  Print  |  Notify Moderator
The 2011/12 F450 also has physically larger brakes compared to the 250/350.
2012 Ford F-350 6.7L 4x4 Lariat CC DRW
A 2008-2009 Tiffin Allegro Bus is in our future...
 > Why go F450?
