Starcraft21SSO
Atlanta, Ga.
My HTT has the screw in type latches. Not only do they rust, I really don't trust them when travelling. Considering replacing them with trailer latched like those seen here; New latches on the Bunk Door
Has anyone else made this mod? Any suggestions/tips/advice? Can you see any reason why I couldn't put some diamond plate on the outside wall to reinforce the fiberglass and forego the thru bolts depicted above?
2002 Starcraft TravelStar (21SSO) Hybrid TT
BIG ALEX
ALBUQUERQUE,NM
Hi have that same set up on my outback 21rs works really well.
Chuck_S
Broadview Hts, OH, USA
The Search function is your friend...
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
llowllms
Crawford, Tn. USA
Chuck_S wrote: The Search function is your friend...
-- Chuck
Absolutely, there has been much discussion on this topic.
Starcraft21SSO
Atlanta, Ga.
My search-fu must be waning today. I searched "bunk latch" figuring that was pretty broad and only got 3 threads, two of which were discussing repair/replacement of the old style with another old style.
EDIT: Found the magic formula. Search for "latch" and limit the search to the HTT forum only. Just using "latch" without the restriction generates too many results and buries the desired discussions in noise. Adding "bunk" greatly reduces results as other spellings like "bunk-end", "bed", and "fold out" are common.
For those who may land here later, here is a link to the search
Search the HTT forum for "latch"
Thanks for the advice.
edited 10/26/11 11:03am by Starcraft21SSO *
bikendan
Napa, Cal.
just Google "Fastec", they make the parts that most hybrids have for the cargo-style latch system.
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever , 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
Starcraft21SSO
Atlanta, Ga.
bikendan wrote: just Google "Fastec", they make the parts that most hybrids have for the cargo-style latch system.
Found that, thanks. Is there a tension adjustment or shims for these type latches? It would seem that the thickness of the door and over/undercompression might be an issue.
Also, has anyone mounted them without drilling through? I'm thinking of affixing a piece 4"x6" stainless or diamond plate with epoxy/screws and using sheet metal screws to attach the latches to that, thus preventing interior penetrations. Not a big deal on the bunk door, but a bit unsightly on the interior walls.
stratmansailing
Michigan
Hi I did this mod last year.
You use foam or rubber pad between latch and hatch to take up any play
Also yes drill threw the bunks to mount latches and use j nuts. It will be flush with the inside of the bunk
happycampin4
Haymarket, VA
Here is a link where i did this a few years ago...
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/21680849/srt/pa/pging/1/page/1
HappyCampin!
HappyCampin4
Me and Her, da boy (19), da girl (14)
Maggie May the bassett/beagle mix. (Front half Bassett, back half beagle, Beagle brain.)
2000 Starcraft TravelStar 21CK
2006 Toyota Tacoma Double Cab V6 w/ Factory Tow Pkg
Reese W/D w/ Dual Cam, Prodigy
camperforlife
Midwest
Starcraft21SSO wrote: My HTT has the screw in type latches. Not only do they rust, I really don't trust them when travelling. Considering replacing them with trailer latched like those seen here; New latches on the Bunk Door
I sent you a PM about some pictures of the Mod.
