RV.Net Open Roads Forum: Class A Motorhomes: Determining wheel cut
 > Determining wheel cut
Page of 5
Nui
Vancouver
Posted: 10/26/11 02:07pm Link  |  Print  |  Notify Moderator
Does anyone know what the wheel cut would be on a 34 foot Winnebago Chieftain? In RV tips, they tell you your turns should be determined by the wheel cut.
Someone said you can use a protractor to figure it out, but even if I owned one, I wouldn't know what to do with it.
docj
Fulltime--Home is where we park it
Posted: 10/26/11 02:14pm Link  |  Print  |  Notify Moderator
IMHO, this type of analytic approach to driving is what you expect to find in a book written by someone who probably has little or no real driving experience. Although some newer RVs can cut their front wheels a bit more than the 53 degrees that had been pretty common, I find it hard to believe that anyone fine-tunes their cornering to that degree. Most people quickly calibrate where the driver's seat should be relative to the corner when making a right turn which is the only really "difficult" driving maneuver you have to make. Since I don't enjoy the thought of cutting a corner and taking down a light pole I usually try to err on the side of making turns wider than needed, anyway.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
rgatijnet1
Posted: 10/26/11 02:26pm Link  |  Print  |  Notify Moderator
Go to a large parking lot and using markers, turn sharply right and left and you will get what it means for your particular coach. Besides the ability of the wheel to turn, the wheelbase also has a lot to do with your turning radius.
Greyghost
On The Road To Somewhere
Posted: 10/26/11 02:33pm Link  |  Print  |  Notify Moderator
Check with the chassis manufacturer. They'll need the VIN and should be able to pin it down for you.
Pat & Roger Fisher
2004 Mountain Aire 3501
2007 Honda CRV EX-L 4WD,
Jewel and Clifford Bouvier Des Flandres
antsinmypants
massillon ohio
Posted: 10/26/11 02:51pm Link  |  Print  |  Notify Moderator
i would use the rear view mirrors rather than trusting a calculation
Hank MI
Brighton, Michigan
Posted: 10/26/11 02:59pm Link  |  Print  |  Notify Moderator
As doj said wheel cut is 'interesting' information. Along with turning radius and chassis overhang, also interesting but until you drive it and understand how all 3 come into play they remain nothing more than interesting.
How sharp a turn the wheels will allow doesn't take into account how much the rear will swing out in the opposite direction. It also doesn't take into account the wheelbase which along with wheel cut determines turning radius. Drive it, use your mirrors and watch closely. You'll soon learn what maneuvers you can and cannot make.
Nui
Vancouver
Posted: 10/26/11 03:04pm Link  |  Print  |  Notify Moderator
Well, like I said - the most logical thing is to drive it eastward until I hit the Atlantic, sell the rig, and buy a new one going west. I do really well on straight stretches
Hank MI
Brighton, Michigan
Posted: 10/26/11 03:23pm Link  |  Print  |  Notify Moderator
It's different but you'll get use to it pretty quickly. Use your mirrors a lot until you figure out where you are in the lane. Always use them when turning or backing up. Pretty soon you'll be a pro. Just remember it is more tiring than driving a car so don't plan on jumping in and driving for 8 straight hours. Get use to it then you'll know how much you can handle. Don't forget weather, wind, and the type of roads will also determine how long you can drive before you need to stop.
Nui
Vancouver
Posted: 10/26/11 03:26pm Link  |  Print  |  Notify Moderator
Funny you should mention that.... I get absolutely exhausted when I drive the Beast. I figured it was tension, or an incipient heart attack or stroke.
Nice to know it's just normal.
Hank MI
Brighton, Michigan
Posted: 10/26/11 03:34pm Link  |  Print  |  Notify Moderator
I can drive all day in the car, it kind of drives itself. The MH, whole different story, at least mine is. I'm not saying it's hard but it definitely is a whole lot different than driving the car.
Page of 5
