RV.Net Open Roads Forum: Hybrid Travel Trailers: Tanks full?
Open Roads Forum  >  Hybrid Travel Trailers
 > Tanks full?
DammitJim
Posted: 10/26/11 02:08pm Link  |  Print  |  Notify Moderator
How do I know when my tanks are close to being full? My Bantam doesn't have a monitoring system and I can't keep count of the people using the toilet or the sink.
Starcraft21SSO
Atlanta, Ga.
Posted: 10/26/11 02:14pm Link  |  Print  |  Notify Moderator
I would install a monitor. That said, here are your options.
The toilet only has one interior opening and you are sitting on it. Look down the hole and don't let it rise above the bottom flange (floor level) or it might leak into the camper. Realistically, about 8-12" inches below the seal.
Being lowest point, the grey water will back up into the shower first. Not a good thing, but not a disaster either. By the time this happens, you are 125% full. Even trying to count, the grey water will fill up much faster than you expect.
2002 Starcraft TravelStar (21SSO) Hybrid TT
Oasisbob
Portland Oregon 97266
Posted: 10/26/11 02:47pm Link  |  Print  |  Notify Moderator
my Bantam has guages above stove on range hood. It is possible you are already wired for guages. They may even already be there if someone has changed out the range hood. ?
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
Chuck_S
Broadview Hts, OH, USA
There are some nice monitors that don't depend on drilling holes in the tank. Not worth the expense for me as I already have a factory fitted sensing system but if you have nothing they're worth looking at.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
downtheroad
Pacific Northwest
Posted: 10/26/11 02:48pm Link  |  Print  |  Notify Moderator
Good advice from Starcraft21SSO above...
except, I would not install a monitor unless you are willing to spend a good deal of coin on a top of the line system and run a lot of wires in tough to get to places...
Most monitors that come installed on these rigs are notorious for being inaccurate and unreliable.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Starcraft21SSO
Atlanta, Ga.
Posted: 10/26/11 03:45pm Link  |  Print  |  Notify Moderator
In accurate? Yes. Accurate enough to prevent a big mess inside? So far for me.
Oh, and I forgot to add one on the black water. If your butt is wet, the tank is full.
bigfooteriam
beautiful b.c.
Posted: 10/26/11 09:17pm Link  |  Print  |  Notify Moderator
on our trailite we have a monitor panel. only for fresh and grey. accurate enough.
the black tanks are small so i have always used the flashlight down the hole trick. the grey tank on ours is, i believe a bit smaller then the fresh tank.
so... if you use a full fresh tank and dont add water to your system, your grey should be full when your fresh is close to empty.
easier to see how much you have used by looking at the fresh tank, then to see whats in the grey.
but... if youre hooked to city water then it would be hard to tell until you see it in the drains.
2005 chevy blazer 4wd
1998 trail-lite 17 hybrid
lotsa mods here and there to fit our campstyle
just havin fun
Executive
Posted: 10/26/11 05:17pm Link  |  Print  |  Notify Moderator
I hope they are only using the sink to wash their hands.........Dennis
That said, the grey tank holds more than the black tank. Usually the grey tank will start to fill up the shower/tub and you will smell it. Same thing with the black tank, it will start to smell when it's close to full......D
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
bikendan
Napa, Cal.
Posted: 10/26/11 06:08pm Link  |  Print  |  Notify Moderator
maybe on your huge DP, but not on his little Bantam hybrid. i seem to remember that the smaller Bantams only had a 7gall. black tank and a 10gall. gray tank.
most hybrids have the same size gray tank as the black tank, mine does.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
skipnchar
Topeka or somewhere else
Posted: 10/26/11 04:03pm Link  |  Print  |  Notify Moderator
When the black tank is near full you will see liquid when you flush the toilet and look down the throat. The gray tank is full when it backs up into the shower or tub. The galley tank is full when it backs up into the kitchen sink. The fresh tank is full when it runs out the fill cap and it's empty when it doesn't pump water through the faucets. That system ALWAYS works.
Good luck / Skip
 > Tanks full?
