RV.Net Open Roads Forum: Fifth-Wheels: Size of bath tub in a 5th
 > Size of bath tub in a 5th
ReneeG
Meridian, Idaho
Posted: 10/26/11 10:31pm Link  |  Print  |  Notify Moderator
sh410 wrote:
remember, the water heater only has 5-10 gal of hot water. Not enough to a good bath!
Some fifth wheels have 12 gallon but still not enough, but a good start. If needed, you could boil extra water for just that one time that you want a good hot soak.
2011 Bighorn 3055RL
2011 F350 SD CC DRW 6.7L Diesel Lariat, Hensley BD3 with Ford Under-Bed Adaptor
Dave & Renee plus (Champ, Molly, and Paris in spirit), Missy, Maggie, and now Mica!
silvercorvette
Anderson SC
Posted: 10/26/11 10:37pm Link  |  Print  |  Notify Moderator
ReneeG wrote:
silvercorvette wrote:
I found a picture but it is hard to judge size from a picture, this one looks like it could be 3 feet long
http://psndealer.com/dealersite/images/lakesidervsales/vp2354310_23_large.jpg
I've seen these in person and they are longer than 3 feet, more like 4 but definitely not one to stretch your legs out in.
I don't care if my legs hanging outside the tub, just as long as I can soak the lower part of my back in hot water. The pain does not get real bad very often but it would be nice to soak in hot water if I really was in a lot of pain.
I once read that studies have shown that most accidents occurr within 10 miles of home, so I moved
Golden_HVAC
Fulltime, CA, USA
Posted: 10/27/11 12:26am Link  |  Print  |  Notify Moderator
Hi,
DOn't let the small water heater stop you. Boil a pan of water, and add that to the tub once it has more than a couple of inches of water in it, and that will warm up the coolish water that will fill the tub. And remember that the RV water heater is 140F, so mixed with 60F water 50/50, you end up with about 11 gallons of 100F water.
And RV water heaters recover fairly quickly, so if you don't have any water run into the tub for about 10 minutes, the water heater can recover from 100F to 140F in that time, just in time to add more hot water to keep the tub warm.
What I might do is using the outside shower, fill the fresh water tank with 6-10 gallons of hot water, then using the pump, if the fresh water tank is above 80F, you can fill the tub with plenty of hot water, or take a longer shower without running out of hot water.
It sure was nice camping in a Country COach, with a 10 gallon water heater. It never ran out of hot water! Some new water heaters use a 160F thermostat, and a mixing valve. The mixing valve mixes the super hot water with cold water, so output is limited to only about 125F, then you can get many more than the standard 6 gallons of water out of the 6 gallon tank.
I have a very small tub/shower. I like that it is a tub, even though I have no chance of sitting in it. I can soak my feet if I ever wanted too, and it works for kids less than 3' tall, the larger ones can take a shower. I can plug the drain, and using a dishpan move some water into the black tank, it is 59 gallons in my RV, while the grey is only 42. My fresh water is 100, so when dry camping in Yosemite, it is handy to move some more water into the black tank.
I am glad that I don't have a standard 3" deep shower pan. I have overfilled the grey tank a few times, and if coming down a mountain with a full grey tank, it can sometimes flow up the drain into the tub, no problem in my case, it will all drain back on the next curve. But with a shower pan, it might not drain back, or will splash onto the floor.
Fred.
Mitchellg
St.Louis
Posted: 10/27/11 08:13am Link  |  Print  |  Notify Moderator
The tub in my 5th is big enough for my 10month old or my 2 year old niece.
Magic Man
Everywhere
Posted: 10/27/11 08:55am Link  |  Print  |  Notify Moderator
http://komfort-rvs.com/index.php?p=floorplans&model=3530FBH#
Komfort by Dutchmen. This tub is five feet long...
bpounds
Whittier CA
Posted: 10/27/11 09:15am Link  |  Print  |  Notify Moderator
I would find an RV park with a whirlpool if a back ache was coming on. Tubs in most RV are just not practical and a waste of floor space.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
farside291
Fort Worth Texas
Posted: 10/27/11 11:35am Link  |  Print  |  Notify Moderator
You can always run the hotwater heater on gas and electric if capable. The recyle time is pretty quick from my experience. I have seen inflatable hot tubs on Amazon for around 500.00. They run on 110V and weigh about 70 pounds when disassembled. This could be an option as opposed to a tub in the fifthwheel. Plus it seats TWO! May not be an option for the winter months but a thought anyway.
2003 Chevrolet C3500, CC, LB, Duramax/Allison
2004 Coachmen Somerset 318RLTS
laknox
Arizona
Posted: 10/27/11 01:34pm Link  |  Print  |  Notify Moderator
The tub in our Komfort is where the litter box goes, when the kitties travel with us. :-)
Lyle
1936 John Deere Model A
farside291
Fort Worth Texas
Posted: 10/27/11 01:36pm Link  |  Print  |  Notify Moderator
Watch out for that clumping cat litter down the drain, sure wreaks havoc with the pipes and the holding tank! Ask me how I know. We did it in our TT we used to have, figured I could just wash the litter down the drain. Bad idea on my part. Now I vacuum the litter out of the tub/shower when the cat travels with us.
zedd
Arizona
Posted: 10/27/11 01:46pm Link  |  Print  |  Notify Moderator
I just went out & measured the tub in our Jayflight. The basin is about 37" x 20" and about 12" deep. It's about 40" x 24" overall. Definitely not large but perhaps usable. We've never used it as a tub, just as a shower and it's pretty tight for me but then I'm 6'-5".
Hope this helps...
2008 Ford F250 Super Duty, Lariat, 6.4l PSD, Super Cab. Long Bed
2006 Jayco Jay Flight 27.5 RLS Fifth Wheel
