DickandVicki
Canton, OH
We have a '07 Keystone Cougar 292RKS 5th wheel with a Suburban water heater. We just pulled our rig from OH to FL to spend the winter. For lack of a better term, we have a "hum" in the water heater and hot water lines whenever we open a hot water faucet (whether the water is heated or not). I thought it might be a lack of an air gap, so I just went through the air gap replacement proceedure (twice) with no change. Any of you ever encounter this problem? Thanks!
2001 F250 SD diesel ext. cab short bed
Banks Six Gun tuner
DW (best friend) of 46 years Miss Vicki
Border Collie/Husky "Miss Nikki"
Retired and enjoying life
downtheroad
Pacific Northwest
Assuming it's not the pump...my guess is that the check valve in the water heater is sticking or beginning to fail.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
greende
Syracuse,NY
Sounds like a check valve either in the water heater or the city water inlet if you are hooked up to city water.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
skylos
Columbus, OH
sounds like a check valve, yes.
Old-Biscuit
Across the USA
Only happens when using hot.....doesn't happen on cold?
Water heater check valve sticking......look at water lines on heater for a cylinder looking fitting (can be on bottom-cold inlet or on top-hot outlet).
Can remove/knock internals out and put back on.............just remember to replace when you go to 'winterize' rig.
tx racer 67
Greenville Tx
Mine sounds the same,will check the valve.
03 chevy
05 cruiser
67 camaro
DickandVicki
Canton, OH
A few weeks ago I finally went and bought a check valve to replace the old one. It really was a straightforward job - but it definitely took a deep dish socket and breaker bar to break the old one loose. That solved my problem, so...on to the next one, whatever it might be.
larry barnhart
wenatchee. wa usa
I gutted our check valve 4 years ago but will replace it if we ever winterize. this would be bad news for us because it would mean we are staying home for the winter.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Mike_LA
Gulf Coast
Noisy water heater thread
2006 Chevy Silverado Crew Cab Z-71 5.3L
Firestone Ride-Rite Air Springs
2005 Jayco ZX24-E Toy Hauler
Prodigy P2 Brake Control
15K Putnam Class V Receiver
10K Equal-i-zer WD
Toy Hauler
