RV.Net Open Roads Forum: Travel Trailers: Furnace Running with Thermostat off ?
 > Furnace Running with Thermostat off ?
kirkl
Washington
Posted: 10/27/11 01:49pm Link  |  Print  |  Notify Moderator
I have a 2005 salem TT and has forced air ducted furnace. to turn if off you just turn down the thermostat to where it says off which is basically 50 degrees is what it says.
theres really no off and on switch. well its been getting cold here (23 last night) and i noticed it was running last night and this morning. is there a way to really shut it off without pulling the batteries out or unplugging it. im getting ready to go elk hunting and its using my propane running it.
2003 Dodge Cummins HO quad cab 4x4 6spd
2005 23ft Salem TT
Honda 2000 Generator
donn0128
Pronounced Ore-gun
Posted: 10/27/11 01:54pm Link  |  Print  |  Notify Moderator
Yea, replace that junk thermostat with a new Hunter Douglas digital one for around 25 dollars. The HD has a switch that actually turns it off.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
kirkl
Washington
Posted: 10/27/11 01:58pm Link  |  Print  |  Notify Moderator
will a digital one always have a little drain on the battery if boondock camping?
nadkaw1957
Reno
Posted: 10/27/11 02:04pm Link  |  Print  |  Notify Moderator
The Hunter has its own batteries - there won't be any drain from your house batteries when you turn the furnace off.
2011 Trail Sport 25S
2011 Ram 1500 5.7L Hemi
donn0128
Pronounced Ore-gun
Posted: 10/27/11 02:05pm Link  |  Print  |  Notify Moderator
No, The HD digital uses two AA batteries for power. So if not wanted/needed you can either turn it off or take the batteries out. They are way more accurate so the temp swings inside the RV are diminished greatly. Making a more comfortable environment.
kirkl
Washington
Posted: 10/27/11 02:06pm Link  |  Print  |  Notify Moderator
sounds good. thanks for the reply. wheres a good place to pick those up?
Gdetrailer
PA
Posted: 10/27/11 02:07pm Link  |  Print  |  Notify Moderator
If you buy the correct digital t stat it will require its' own batteries in order for the T stat to work.
Read the package carefully, some digital home T stats like the Honeywell "Round" series are designed to sneak power from the furnace to charge a battery or a capacitor. This type will not work correctly since home furnaces are designed for 24V AC and your RV furnace will only have 12V DC.
The T stats you are looking for should state requires batteries.
McDaddy
Saugus, Ma
Posted: 10/27/11 02:10pm Link  |  Print  |  Notify Moderator
You can get a Hunter at Home Depot. Also, if you do a search you will find that the moderator Les has a great install procedure so that if you can have high and low fan speeds.
donn0128
Pronounced Ore-gun
Posted: 10/27/11 02:17pm Link  |  Print  |  Notify Moderator
WalMart also sells the one you need for around 20-25 dollars or get it off of Amazon.com
nadkaw1957
Reno
Walmart is where I got mine
