Most of the information is on the various labels and manuals that came with the
vehicle.
The GCWR is the tough one to find. I didn't know of its existence till ordered my
1996 Suburban. Even then didn't pay much attention to it till I bought into a
big boat partnership. It was over 8,500 lbs and more when the stuff tossed into it
Generically the GCWR is the TV CURB weight plus the MTWR. Then there are
a few other things you need to know that has already been mentioned. Like the
fact that they used a 150lb driver, the tow option and a 10% tongued trailer.
Don't know what they used for a Fiver based, but in the same direction, think
they used the lowest PIN percentage (normally they range from 20%-25%, so assume
the used a 20% PIN trailer).
I have a link for GM's media site, but don't know them for other badges. Maybe
someone will post a link for you
Here are some examples of the various labels on both the TV and Trailer
-Ben Picture of my rig
2000 Ram 2500 towing specs It looks like you have a towing capcity around 12000 lbs with the big 8.0L. Want to stay under 10000 lbs loaded trailer.
A 6200 lb dry trailer will probably weigh around 7200 lbs loaded with options and gear.
7200 lbs x 13% tongue weight minimum percentage = 936 lbs of tongue weight.
You will need a weight distribution hitch to tow that much tongue weight safely. A. you don't want to exceed your receiver's capacity and B. you need to get the weight you'll remove back on the front end for better stability.
I'd recommend the 1200 lb bars with 10000 lb head.
THEN you need to set it up correctly and use good sway control, a whole other topic of discussion
edited 10/31/11 06:08pm by eric james *
DW-gray wrote: Here's another website that has towing guides: Fift Wheel St.
That one only goes back to '04. The other one goes back to '91, IIRC. I'm still looking for one that goes back to '79.
What are you specifics are you looking for in the '79? That may be a challenge but I'm up for it. Please provide the info shown on the Certification Label.
edited 08/12/12 03:07pm by DW-gray *
