RV.Net Open Roads Forum: Class A Motorhomes: Problems after Norcold recall?
 > Problems after Norcold recall?
TEO
Inverness, FL, USA
Posted: 10/30/11 07:58am Link  |  Print  |  Notify Moderator
We took the motorhome out for the weekend, the first trip since the last Norcold recall. The refrigerator will not run on LP gas. Thinking that it has been such a long time that it might take a while to get the air out of the line, I tried dozens of time to get the gas to work. I will not! I've got the number of a Norcold Service Center when I get home, but it occurred to me that the refrigerator has not been used since the recall. Has anyone else had this problem or knows of someone else with the problem? I'll be contacting the dealer who did the recall in the morning. If I had any additional info it would be good.
Thanks, Paul
Paul & Helen
2002 Winnebago Journey DL
1999 Jeep Cherokee toad
Yellow Lab, Jodie, Chocolate Lab, Coco , and Lab/Golden mix, Sandy.
FMCA 98905
http://ptempesta.blogspot.com
03FatBoy
Crossville, Tn.
Posted: 10/30/11 08:35am Link  |  Print  |  Notify Moderator
How long since you used it? Could be bad propane in the line. Start a couple of the stove burners and make sure the line is cleared. We had the same problem with the hot water heater last time out. I remember after a winter of setting it used to take up to 5-6 tries to get the burner on the fridge to stay lit.
Melissa & Steve (MNC USNR retired)
FMCA F335327, GS
'05 HR Ambassador 36PDD, Saturn Vue Toad
8.3L Cummins w/ 6sp Allison
enblethen
Moses Lake, WA
Posted: 10/30/11 09:01am Link  |  Print  |  Notify Moderator
Could they have left the gas valve off?
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
dougrainer
Carrolton, Texas
Posted: 10/30/11 09:10am Link  |  Print  |  Notify Moderator
If it runs on 120, then it depends on which part of the recall was needed. Some recall installs do NOT involve removing the rear control board cover. That means they did not interfere with the gas valve or other controls. The recall on newer refers require the rear cover to be removed and they have to disconnect the spark ignitor wire and the 2 gas valve wires. If they did not reinstall the gas valve wires or damaged the spark electrode piezo, then the lp section would be affected. Last, when we do the recall we always blow out the burner to clear any possible debris/rust. Your problem may be as simple as rust/debris has fallen on the burner during the recall or just from lack of maintenance. We ALWAYS start the refer on LP and verify amp draw on 120 after we do the recall. Customers should ALWAYS verify the operation on LP after the recall is done before they leave the Service Center. It takes less than 5 minutes. Doug
generalexam
usa
Posted: 10/30/11 09:56am Link  |  Print  |  Notify Moderator
exactly what iam also thinking.the recall has no bearing on the lpg
system as its strictly a high temp shut off system
did it work ok on 120V ??
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 10/30/11 10:16am Link  |  Print  |  Notify Moderator
I think you mean 'left it in the OFF position'. It's likely.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
TEO
Inverness, FL, USA
Posted: 10/30/11 10:42am Link  |  Print  |  Notify Moderator
The gas valve is on and the stove is working fine. Set to LP, I can hear the clicking of ignition, but there is no flame. I want to check with the dealer in the morning before I start into the unit myself.
Thanks for the help.
Paul
Jim@HiTek
Gresham, OR, USA
Posted: 10/30/11 10:59am Link  |  Print  |  Notify Moderator
You might save a trip to the dealer if you check that the propane valve in the outside cabinet is getting voltage. It should be easy to get to and obvious where the wires terminate. A voltmeter and someone to turn the refer 'On' while you monitor the voltage are all that is necessary. While it's sparking, the valve should be getting 12V.
Then there are two fuses in the control and/or there could have been a mis-wiring while doing the recall...
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
enblethen
Moses Lake, WA
Posted: 10/30/11 11:10am Link  |  Print  |  Notify Moderator
I am not talking about the valve on the LP tank, but there may be a valve behind the refer.
TEO
Inverness, FL, USA
Posted: 10/30/11 11:27am Link  |  Print  |  Notify Moderator
Yes, there is a manual valve next to the electric valve behind the refer. It was in the on position.
