RV.Net Open Roads Forum: Class A Motorhomes: Problems after Norcold recall?
 > Problems after Norcold recall?
enblethen
Moses Lake, WA
Posted: 10/30/11 11:33am Link  |  Print  |  Notify Moderator
Can you see the igniter firing? If yes, check for power to the gas valve while the igniter is firing.
Could be an open in the valve circuit.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tinstar
McKinney, TX
Posted: 10/30/11 01:02pm Link  |  Print  |  Notify Moderator
Use the KISS method. Clean the burner first. That's the most common culprit. Then move on to igniters, gas valves, regulators, etc.
">Never pass up a chance to go somewhere">
gatorcq
Arizona
Posted: 10/30/11 01:09pm Link  |  Print  |  Notify Moderator
The recall interrupt's the 12vdc to the board. So that is not the problem. You've stated the ignitor is working, gas valve is on and yet no flame. Have you checked for codes on the display?.
Have you verify DC voltage to the gas valve when it is trying to ignite?
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 08 Jeep Liberty
Roadmaster and Air Brake System
1600Ws MPPT, 2800Ws Inv/Chg, 660AH
Alfa SeYa 2003, CAT 3126E 330Hp (Previous)
DaGirslRV Blog
obgraham
TriCites WA
Posted: 10/30/11 02:49pm Link  |  Print  |  Notify Moderator
Open up the plate covering the bottom of the flue. In there is where the flame lives, and the igniter pops its spark into the gas there. It's likely that there is a bunch of flaky crud sitting there obstructing the whole process. Vacuum all that out of there and try it again.
Worked for me.
TEO
Inverness, FL, USA
Posted: 11/04/11 06:25pm Link  |  Print  |  Notify Moderator
Here's what I did. The assembly on this reefer is way different from what I've had in the past. In addition, there has been some modification due to the recalls, one being the installation of some stick-on insulation.
We're heading on a long trip, and I didn't want to worry about a fire in the motorhome, so I called the RV Doctor, a local guy who makes motorhouse calls (that's a pun). He came to the house and worked on the burner. The rust was considerable and the igniter was broken. The clicking that I hear was the spark to ground, not the burner. When he finally got the burner running it would fire and spit, fire and spit, as if there was some air on the line. He had to replace the burner. I have a fine flame and the reefer functions as it is supposed to. Most important, I was looking over his shoulder and I'm sure it was done right, so I will not have to worry about fire. Now, I can leave tomorrow in peace.
Thank you for all your suggestions, but some of it was over my head.
Paul
Paul & Helen
2002 Winnebago Journey DL">
1999 Jeep Cherokee toad ">
Yellow Lab, Jodie, Chocolate Lab, Coco ">, and Lab/Golden mix, Sandy.">
FMCA 98905
http://ptempesta.blogspot.com
