ilvtravln
Calif.
We have an 09 Bighorn. We usually camp one week at a time. I drain the grey water daily, never have a problem. I drain and flush the black tank at the end of the week and have never had a problem until now. When I drain/flush the black tank now only part of the stuff comes out. I then drive home and after everything bounces around awhile I flush/drain at home then the balance comes out no problem. Do I need to flush more often while camping or is the black valve not opening all the way ? But if the valve is not opening completely then how come I can drain at home no problem ? Thanks for any input.
Art
Tvov
CT
Sounds like maybe just the most recent times you have not had enough water in the black tank? Before you drain it, do you "top it off" with water?
2008 F-250 CrewCab 5.4L,
CREATO
Beautiful Harvey N.D.
STart with about 3 gallons of water in the black tank that way stuff wont be so apted to stick to the bottomo of tank
I dont rent out space in my brain
ilvtravln
Calif.
No, I don't top it off, but I will try that. Thanks
PS When I hook it up to flush there is plenty of water going in but little comming out !!!
edited 10/30/11 10:38am by ilvtravln *
gbopp
The Keystone State
Your black tank should be 3/4 full or more before you dump.
Topping off with water should solve your problem.
brirene
midwest
My thoughts were not enough water also. Also, don't drain it until you need to; the fuller it is, the better the draining action. I think most people also drain the grey tank AFTER the black tank, to help flush out the hose. Really no need to drain it everyday.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
VirtualMe
Cedar Falls, IA
brirene wrote: My thoughts were not enough water also. Also, don't drain it until you need to; the fuller it is, the better the draining action. I think most people also drain the grey tank AFTER the black tank, to help flush out the hose. Really no need to drain it everyday.
That is, unless your filling it up daily with showers and such...
ilvtravln
Calif.
I drain the black tank only 1X at the end of our stay but it sounds like there should be more water in the tank. Thanks
rockintom
Livingston, TX
ilvtravln wrote: We have an 09 Bighorn. We usually camp one week at a time. I drain the grey water daily, never have a problem. I drain and flush the black tank at the end of the week and have never had a problem until now. When I drain/flush the black tank now only part of the stuff comes out. I then drive home and after everything bounces around awhile I flush/drain at home then the balance comes out no problem. Do I need to flush more often while camping or is the black valve not opening all the way ? But if the valve is not opening completely then how come I can drain at home no problem ? Thanks for any input.
I agree with the others, not enough water. Do you have any new folks using your throne? I always tell folks using ours that aren't used to using a RV toilet, if you have paper with pee......flush 4 seconds, 7 seconds with poo. Someone using way too much TP can cause stock piling and problems too. I usually start my sewer flush a few seconds before pulling the lever on the black tank, unless it's way full. Hope this helps. rockin'
Rockintom
'12 Excel Limited GKE 33 ft., trailer named "Charm"
'05 1 ton Chevy DRW Max&Allie Racor 660 Aux. Fuel Filter
Line-x Reese 20K hitch Prodigy controller GM nurf bars and folding bed cover - truck named "Tug" Fulltiming
houtrz
Lake Jackson Texas
More water. I will fill mine to the top then dump, then I'll fill it up about half way and dump again. No problems.
On your valves, are they cable operated or do you have actual control of the valve. Mine are cable operated and there seems to be some play in mine that wasn't there before.
