TimOnTheRoad
Colorado-Maine
I searched and didnt find anything on this...I have a skylight directly over my bed, and if I lay down for a while in the afternoon, which I need to do once in a while, it is way to bright in there. Does anyone know of an after market blackout shade that can be mounted over these to block out the light? Thanks for any input here...Tim
deereone
NE
I have used in the bedroom area a plastic corrugated material very much like cardboard. It's the material sign makers use for a lot of there small outdoor signs. You can buy it from most any sign shop and comes in many colors. To hold it over the skylight use those plastic clips used to hold a mirror.
Executive
Go to an upholstery shop and get yourself a piece of foam material and cut it a little bigger than the opening. When you want to block out the sunlight, simply push it into the opening. Camping World sells them but you can get the same thing for less than half the cost at the upholstery shop. A sympathetic owner may simply give you a scrap piece......Dennis
Camping World Vent Cushion
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
mikestock
Vestavia Hills, AL, USA
Executive wrote: Go to an upholstery shop and get yourself a piece of foam material and cut it a little bigger than the opening. When you want to block out the sunlight, simply push it into the opening. Camping World sells them but you can get the same thing for less than half the cost at the upholstery shop. A sympathetic owner may simply give you a scrap piece......Dennis
This is what I did but also used spray glue on the top side of the foam and glues black polyethylene. This really blacks it out. I've used the same pieces for 12 years with three different fifth wheels.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
christopherglenn
a little over an hour from Yosemite
If it is the standard 14x14 rv places sell vent pillows to plug the hole. If it is larger, like the shower size, the shades for entry doors and velcro work well. Anything that blocks all the light will block all the airflow as well.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
TimOnTheRoad
Colorado-Maine
That is perfect!! Thanks much for the heads up on this!! Tim
RoyB
King George, VA
Think VELCRO
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
96Bounder30E
America is my home!
At the time, there was nothing on the market that did what I wanted it to do.......and that was to block out the light from the roof vents that did not result in a separate piece that I had to store when not being used.......such as a pillow or velcro stuck on square cover.......
So, I went to Home Depot and purchased an off the shelf roller shade that was more than double the width of what I needed.........I then disassembled the shade and cut it down into 2 smaller shades.....I then built a plywood box to house the roller and covered them with matching ceiling carpet......all in all, it was a fun DIY project!
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
LowRyter
OKC
I cut a piece of cardboard from a box and wedged it in there. I wish I could remember the brand of Irish Whiskey that is printed on the box so you could do it right.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
hmknightnc
Wilmington, NC
Black MaxAirr covers is what we use. You can leave the vent open in all weather also
