RV.Net Open Roads Forum: So what did you do to your Truck Camper today?
 > So what did you do to your Truck Camper today?
Page of 129
nkrantz
Farmington Hills Michigan
Posted: 03/13/12 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Gave it a new truck. Added led lights to inside and motion sensor lights outside,
AF 1140 2 optima yellow tops Honda eu3000 honda eu 2000 companion
2012 Ram 3500 DRW Roadmaster Sway Bar, Airbags, stableloads, superhitch, Buckstop bumper, carli lift, Alcoa's with 3970lb toyo AT's
joerg68
Ueberherrn, Germany
Posted: 03/13/12 06:32am Link  |  Quote  |  Print  |  Notify Moderator
No pictures, and not today but over the past weekend:
- thoroughly cleaned the outside
- fixed a kink in the water tank pressure relief line. Much better water fill now :-)
- filled fresh water tank
- hooked up LPG
- tested all systems
... ready to go on the first trip for 2012!
-J
"Pickups are very handy cars. One step on the brakes, and everything you need is right behind you!"
JumboJet
Tontitown Arkansas
Posted: 03/13/12 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Is that a TDR emblem on the grill?
nkrantz
Posted: 03/13/12 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Yes sir are you a member
RockyRoadCamper
Browder, Ky, USA
Posted: 03/13/12 07:30am Link  |  Quote  |  Print  |  Notify Moderator
I talked to a truck service place about adding one main leaf spring to each side of my 2008 F-450. Have to use new spring bolts. Cost estimate around $500-$600. Think I will do that next week. No sag or sway or steering issues now but the back of the truck is still lower with the big Okan t/c with two slides. I have tried several things, best so far is the block-name?-between the springs and helper springs that gets more use out of the helper single spring, but as the back is still lower I want it level and I do not want air bags. Timbens did not do anything I can tell.
joe123
home
Posted: 03/13/12 08:36am Link  |  Quote  |  Print  |  Notify Moderator
replaced the power converter,with one that will keep my batteries charged,replaceing the hood fan with something that will not make so much noise, replaced both valve to propane tank lines with old style not the plastic nut i need to use a wrench to tighten.More later as we are going to alaska and the yukon for two months starting in may.
JoeChiOhki
Sauvie Island, OR
Posted: 03/13/12 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Heading back to Home Depot because the bulbs I first got worked, but the ones I decided to switch to won't, so one more time into the breach!
CB Channel 17 Redneck Express
MAV 8801
MONT CLARE PA
Posted: 03/14/12 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Got home earily last night..and de-winterized the TC..flushed the lines and tank with water and bleach.. Gave it a good rinse this morning; refilled the tank and letting it drain again..Also oiled the Wineguard antenna and all the locks..
2011 Palomino Maverick 8801, 2005 Chevy 2500HD Crew Duramax/Allison, Timbrens, Bilsteins, Michelin LTX M/S2, Hypertech programer & Honda Eu2000
JoeChiOhki
Sauvie Island, OR
Posted: 03/14/12 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Got my new light fixture installed . It makes the old lights look extremely dim by comparison!
Mello Mike
Mesa, AZ
Posted: 03/14/12 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Pics?
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
Page of 129
