RV.Net Open Roads Forum: So what did you do to your Truck Camper today?
 > So what did you do to your Truck Camper today?
Page of 130
jtlingo123
Snoqualmie, Washington
Posted: 07/30/12 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hey thanks!
One of these days I'll figure out how this works!
Josh Lingo
Snoqualmie,WA.
langenc
Montmorency Co, MI
Posted: 07/31/12 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Fiddled with the water line drain 'valves'. It seems they want to leak all of a sudden.
I need to do something with the water tank drain valve, plastic and it needs to be turned 180 to drain. A real bear to turn.
Suggestions?? Any kind of lube I can put on the plastic to make it 'slide' easier?
jtlingo123
Posted: 08/01/12 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Langenc,
White lithium grease works good, it's safe on all sorts of stuff. A little bit goes a long way! I don't think it will damage plastic.
ggadwa
Stanley,Idaho
Posted: 08/04/12 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Nelson's RV in Garden City Idaho....did a Warranty replacement of our Polar Cub A/C on our 2011 Eagle Cap 950....So we immediately set out for a night of Camping out with our NEW A/C....Year old AC never worked even once now with the "new" Polar Cub and our Honda 2000 generator we are cool and comfy....So that's what I did yesterday and today!!!!
Nelson's Service is GREAT!!!
GARY
EAGLE CAP 2011 950 CUSTOM BUILT
2012 FORD 350 6.7 L Diesel 4x4 Super Cab
freddypinak
Nevada
Posted: 08/04/12 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Purchased a new battery for the camper. Wanted to go with 2 of the 6V golf cart batteries but couldn't fit them in the battery box of our little Lance SquireLite 165. Went with the Energizer Deep Cycle marine battery from Sam's Club. We got 6 years out of the last battery, so we're not complaining. Guess changing all the lights to LED did help :-)
2006 Chevrolet Silverado 2500HD 4x4
1998 Lance SquireLite 165
sleepywheel
Vancouver, BC
Posted: 08/04/12 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Finally got around to having a look at the water leak behind the shower faucets and found the plastic tube between the taps that feed the shower hose was cracked. When we bought the used camper, we noticed the leak so never used it. I guess someone didn't antifreeze the system for the winter and the water froze and cracked the pipe. Is the part available separately or can I find a replacement setup at Home Depot?
Picked up my Firestone air bags today and maybe install them tomorrow.
Started on my rear porch, mostly done but need to pick up some wood for the deck and figure out what to use for the cable to hold the deck level in the down position. Is clothesline strong enough with the U shaped clamps?
2009 Chev CC 2500HD 6L 4x4
2007 Palomino Bronco 1251SB popup
AKsilvereagle
North Pole, Alaska
Posted: 08/04/12 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
Had to remove the camper shell off my rig last week in order to have the windshield replaced since some numbskull in BC was driving real fast (a double trailer gravel loaded semi) without covering their load last September 2011 as I never seen what hit the windshield, just heard the hard impact and had glass fragments all over my lap as a result :
This was the second time this truck was ever camper shell-less by me since owned in 1996, but does look pretty with a perfect windshield for the first time under my ownership :
Since the camper shell was removed, I decided to go ahead and solidly repack the front inner and outer wheel bearings (LMX red grease) after only 15,100 miles according to my log since the last repacking task, as I thought it was a good idea to inspect the wheel bearings anyway because of the camper shell I have now since 2008 makes the total front axle weight 240 lbs past it's maximum weight rating (driver, passenger, with both fuel tanks full)... very little red grease broke down and little wear marks on the center portion of the wheel bearings where they contact with the spindle (normal) as the spindles and rotor race surfaces showed no signs of wear marks....wheel bearings still in great shape overall.
Aside from that, greased the front end and the driveline as always prior to departure on a camping trip, added 3 ounces of gear oil to fill the differential that is still fresh, and squeaky cleaned the back cab window of the truck as it was dirty.
As for the camper shell while sitting on jacks, snugged up every screw and bolt all along the camper shell that you could not get to when installed on the truckbed, and lubricated the camper jack poles with silicone spray, also lubricated the threads on the spring loaded turnbuckles prior to reinstalling and adjusting, also gave the Honda 2000i a little running exercise as I rarely use it anyways.
Now I am amped as I started loading up the camper with some of the inventory listed items to cut preparation time and truck maintenance time as the boss granted me three weeks off (would not go for four) between late August or after Labor Day Weekend depending on the workload (as my job mainly consists of no summertime off), so my camper is practically ready to go explore some more far north adventures of Alaska and Canada.
1970 Ford F250 2WD Sport Custom (Owned April 1996)
390 V8 (23K Rebuilt Mi) C6 Trans (207K Original Mi)
2000 Fleetwood Angler 8ft Cabover
Air Lift 1000(Front)
Air Lift Loadlifter 5000(rear)
Hellwig Front and Rear Sway Bars
Goodyear G171 LT Series(siped)
jimh425
Western WA
Posted: 08/04/12 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
No pics but I should have taken them.
I painted the lower wing area black. I don't backup very much in the dark, but I'm sure it will help compared to the old white. My wife did most of the work and I sprayed after she taped it off.
DW also did painting of her own. She painted the letters on the front where the decal used to be. I think it looks good.
A couple of days ago, we replaced the truck batteries. They were do at 6 years.
We also detailed the camper doors, camper, and truck. Kind of strange day to do it since we were having a heat wave.
I'm probably going to break down and add the duh system tomorrow before I reload the camper. We'll see.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
Buzzcut1
Norcal
Posted: 08/05/12 07:10am Link  |  Quote  |  Print  |  Notify Moderator
woking a horse show from the TC at one of my more frequent venues
I thought I'd share the video of my wife winning her class
this is her latest musical freesyle She had one of the high scores of the competition
kind of fun getting paid to watch her ride
enjoy
http://youtu.be/-WE-n4t4K3k
03 F350 Diesel 4x4 Crew Cab long bed, 08 Lance 1055, Rancho 9000xl, Air Lift air Bags, Torqlift tiedowns,stable loads, super hitch, 48" super truss, Toyo 285/75R16 Opencountry HT
PEIwoman
SLC, Utah
Posted: 08/05/12 11:57am Link  |  Quote  |  Print  |  Notify Moderator
F100jetmech wrote:
Installed a bottle opener. I didn't want to create a potential place for water intrusion by mounting on the siding, so I put it on the ladder. Worked out pretty well, it faces the door.
I love this mod!
Way to go!
PEIwoman
2003 Dodge HO QC SB 4x4, BigWig, Fast Guns, Air Lift Bags, Bilsteins, Modded
Looking for the right Truck Camper this Spring
**could it be a Northstar 8.5 Arrow?
Page of 130
