Camper_Jeff_&_Kelli
Seattle
I have a replacement 45 AMP BoonDocker power supply coming Friday so I needed to get my 4 AWG wiring upgrade finished. Got the battery compartment done and made all the connections to the new power distribution block. Installed a 100 AMP breaker on the main battery power lead. Routed 4 AWG wire to the new Power supply location. Installed contingency wiring for a power inverter. Eliminated about 10 feet of length of wires from what the old arrangement was and is now 4 AWG. There are a few more associated projects to complete before I have the TC the way I want it.
Camper Jeff and Kelli's Blog!
Mello Mike
Mesa, AZ
Camper_Jeff_&_Kelli wrote: I have a replacement 45 AMP BoonDocker power supply coming Friday so I needed to get my 4 AWG wiring upgrade finished. Got the battery compartment done and made all the connections to the new power distribution block. Installed a 100 AMP breaker on the main battery power lead. Routed 4 AWG wire to the new Power supply location. Installed contingency wiring for a power inverter. Eliminated about 10 feet of length of wires from what the old arrangement was and is now 4 AWG. There are a few more associated projects to complete before I have the TC the way I want it.
Sounds great. The 4-AWG will serve you well.
2011 Wolf Creek 850N/Polar Cub/240w Solar/2-6v Lifeline AGMs/Morningstar Sunsaver w/RM-1 & SureSine-300 Inverter
2011 Ford F-250/6.2L/3.73/Bilsteins/Air Bags/Torklift TD w/Fastguns
2004 Jeep Wrangler/4.0L/5-spd
US Navy Ret.
My Truck Camper Adventure Blog
dakonthemountain
Crestline, California
Mello Mike wrote: Camper_Jeff_&_Kelli wrote: I have a replacement 45 AMP BoonDocker power supply coming Friday so I needed to get my 4 AWG wiring upgrade finished. Got the battery compartment done and made all the connections to the new power distribution block. Installed a 100 AMP breaker on the main battery power lead. Routed 4 AWG wire to the new Power supply location. Installed contingency wiring for a power inverter. Eliminated about 10 feet of length of wires from what the old arrangement was and is now 4 AWG. There are a few more associated projects to complete before I have the TC the way I want it.
I'm right behind ya! I'm ordering mine next week, along with the Trimetric meter...
Dak
1995 Weekender model 910 extended cabover
Calvin, the 1996 creampuff Chev Silverado 3500 extended cab dually
Escapee #22435
Camper_Jeff_&_Kelli
Seattle
The Trimetric is on the wish list. More important items first like a second solar panel.
recycler
michigan
put up some more foam board insulation
1968 franklin 11fk
back to my 93 cummins
W6EOD
Swansboro, NC
Replaced two Bargman amber marker lights.
2011 Chevy 3500HD Duramax/Allison Combo, 2001 Palomino Maverick 1000
dakonthemountain
Replaced the yellowed outside stove vent damper assembly.
Dak
JoeChiOhki
Sauvie Island, OR
Put battery watering caps on the Group 27 Deep cycle under the hood of the truck and topped up the water in all the batteries.
Enjoying my new second set of Wobbl-Stoppers with the high winds blowing through and the camper not moving a budge.
CB Channel 17 Redneck Express
clinthia
Flathead County, Montana
Not actually today but, recently.
Replaced the old batwing with a Jack antenna.
and installed digital thermostat.
Clint
2007.5 Dodge 3500 4X4 Crewcab with 6.7 Cummins
2004 EC950 w/ slideout
2 Costco 6 volts
Yamaha EF1000IS
Kyocera solar panel
GO POWER 300 watt 12 volt PSW inverter
TorkLift tiedowns with Fastguns
Timbrens
Homemade bumpstops
The Schnauzers Madeline & Genevieve
Brad820
NW ARKANSAS
Washed, waxed, cleaned interior, on our "new to us" 1999 Lance 820. Still have a lot to do to it before it is useable, but this is my first truck camper. Thanks Dan - you know why,
