RV.Net Open Roads Forum: Tech Issues: Set-back thermostat for Suburban furnace
 > Set-back thermostat for Suburban furnace
wjpitura
Lake Country, British Columbia, Canada
Posted: 10/30/11 04:50pm Link  |  Print  |  Notify Moderator
Thinking this should be a non problem, however, better check before I go forward.
Never seen this in a travel trailer, however must be, perhaps in 5th wheelers or motorhomes.
Anyone installed a programmable setback thermostat, like a Honeywell programmable Pro4000 thermostat, which can be set to have the furnace/ac system come on and off automatically?
Personally, I am tired of having to get up after a good nights' sleep and manually turn on the furnace to heat up the trailer. Especially when we are camping in the cooler months or cold evenings.
Seems so logical, this kind of unit works so well in our home.
Anyone tried this or heard of it being done?
Thanks,
-- JP
Chris Bryant
DeLand, Florida, USA
Posted: 10/30/11 04:59pm Link  |  Print  |  Notify Moderator
In general, any thermostat that has batteries in it, and that says it will work with both 24 volt and millivolt systems will work fine.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
wjpitura
Posted: 10/30/11 05:17pm Link  |  Print  |  Notify Moderator
So there is a really good reason why I have never heard of one being installed. Given we do a fair amount of dry camping, don't know why I did not think of battery vs AC power.
Thank you for turning the light back on.
However, perhaps there are units that could work in both conditions and someone out there knows about them.
-- JP
n7bsn
Yes
Posted: 10/30/11 05:38pm Link  |  Print  |  Notify Moderator
Hunter (at least used to) make one. The problem is, you lose the two-speed fan option with the Hunter.
It does take knowing which wire does what
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
ronfisherman
SE Michigan
Posted: 10/31/11 04:46am Link  |  Print  |  Notify Moderator
I have this model in our MH. Hunter 7-Day Programmable Thermostat
Works good for my Suburban furnace and Dometic AC.
Kodiak Chassis Class C Forum
