bill13924
California
We have a 2006 Bounder. We are full timer's, while we are traveling the sewer gas smell is very bad. Can you help?
rvten
Crossville,TN
Traveling with windows and roof vents open will tend to draw oder from the BLK/Gray tanks.
There are also vent pipes in the galley and bathroom. These vents may need replacement some times. New vent cap can be found in any home supply store.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
Helimech
Chino Valley
I use the cyclone, Fixed my gas problem.
hershey
Albuquerque,(fulltime) NM, USA
There are all kinds of solutions to this problem, keep windows closed, keep water in all traps etc but the easiest solution is as posted above, get a Cyclone and your problems are over with.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
gbopp
The Keystone State
Some like the Cyclone RV vent.
pulsar
Lewisville, NC
Moved from Forum Technical Support to Tech Issues.
Acampingwewillgo
My problem with this revolved around "negative" air pressure. Creating any vaccum at all will pull gases from traps and ill-fitting toilet gaskets. So.....keeping water in traps is an excellent idea, proper venting is another But sometimes opening or closing a window here or there solves the problem without much effort....this has been my experience anyways. Good Luck
96 Vogue Prima Vista 37' CAT 3176B
Our Babies: Mollie, Rubie, Cassie and Maggie, all rescued Cavalier King Charles Spaniels
Rainbow Bridge: Laddie, Scoutie, Katie, Cooper, Kodie
Rally's and get togethers.....Lots
popeyemth
owensboro ky
zillions of miles have been travelled without sewer odor and without buying the "CYCLONE" opperate the systems correctly as outlined above and you wont need to buy that overpriced gadget.
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
phillyg
Front Royal, VA
popeyemth wrote: zillions of miles have been travelled without sewer odor and without buying the "CYCLONE" opperate the systems correctly as outlined above and you wont need to buy that overpriced gadget.
Well, not always. I had a '96 Bounder with the same problem. I took good care of my tanks and knew to keep the p-traps full. Since there's no p-trap for the Thetford toilet nothing could be done except keep an inch of water in the bowl. Vents were clear, too, but we learned how to live with the slight sewer smell that occasionally wafted in when traveling. Same thing in our '86 Class C.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
Pangaea Ron
Anacortes, WA, USA
I added Cyclone vents on my former Class C and it solved the problem. It also made the MH look faster,
2008 Itasca SunCruiser 35L
2000 Jeep Grand Cherokee Laredo
