RV.Net Open Roads Forum: Class A Motorhomes: Trickle Chargers & Chassis Batteries
 > Trickle Chargers & Chassis Batteries
sepisllib
Cresco, Iowa
Posted: 11/03/11 06:40am Link  |  Print  |  Notify Moderator
After both my heavy duty chassis batteries failed two weeks ago (both were the 950 cc Interstate ones) - I got to checking and up to now I always thought my Inverter was connected to provide a constant trickle input.
Found out that is not the case and I believe I would like to correct that.
When I owned the Tourmaster I installed a small cheap little trickle charger for my chassis batteries and never had an issue - however I always wondered just how long the cheapies lasted.
Anyway - thinking of installing something now, but am wondering whether or not a solar trickle charger system might be better. Then, of course, not sure for the wattage one should put in for the twin 950 cc batteries.
It would be easier to just buy and mount an AC powered trickle charger as the electrical input is close, and the solar would need to be installed on the roof and leaks snaked down.
Just was wondering how many of you out there had considered, or done this same thing and what you decided to do.
Thank you in advance
God Bless
Bill
Bill W. Trammell
Wife - Judy
2001 Monaco Dynasty Chancellor
2008 Malibu 2LT toad
JohnnyT
Goshen New York
Posted: 11/03/11 02:03pm Link  |  Print  |  Notify Moderator
Bill, here is what I use... Battery Tender
Hank MI
Brighton, Michigan
Posted: 11/03/11 07:28pm Link  |  Print  |  Notify Moderator
I bought a Craftsman battery maintainer. It has clamps, ring connectors and a cigarette lighter plug. I plug it into the cigarette lighter. The converter maintains the house batteries but not the chassis battery. This way both are covered.
infogeek
Hartford, CT
Posted: 11/03/11 08:00pm Link  |  Print  |  Notify Moderator
How does this gadget work (ie how does it install)?
Jon
kdk
usa
Posted: 11/03/11 08:10pm Link  |  Print  |  Notify Moderator
Bill; I installed a "Trik-L-Start" 3 years ago and have never had anymore battery problems. Very easy install and inexpensive. Also put a toad charge on my toad to keep it's battery up while towing. kdk
06 Holiday Rambler Ambassador
11 Buick Lacross
Gamoore
West Sacramento
Posted: 11/03/11 08:16pm Link  |  Print  |  Notify Moderator
Dittos for the "Trik-L-Start". I've this on my coach for a number of years now and have never needed to use the auxillery start switch since.
Diesel Driver
2001 37' Harney Renegade Classic
330 HP CAT
2007 Saturn Aura XR
jwmII
out west
Posted: 11/03/11 08:20pm Link  |  Print  |  Notify Moderator
As mentioned by others here, The Tric-L-Start is a great product. I have it installed on mine and all is well.
jwmII
Viewfinder
Western, NJ
Posted: 11/03/11 10:02pm Link  |  Print  |  Notify Moderator
Tric-L-start. Hook it up and forget about it. If you add a solar system later, no changes are required.
jim
