lushy
N.W. Indiana
I just purchased a 2011 Jayco Jay Feather Select 29L and I noticed that I am going through water much faster compared to my last TT. We are not doing anything different, as far as water usage, and we seemed to go through the water much faster?? I know my fresh water is a little smaller, 28.5 vs. 36 gallons, but I have taken that into consideration already. I am thinking that it may be the kitchen faucet or shower head? Is there a way to cut back on the water flow/usage without buying new faucets? Thanks.
Dandy
NorthEast
Install premium water-savers on the fixtures.
Change the shower head to a water-saver.
Install a flow restrictor on the pump.
Reduce the pumps operating pressure with a different switch.
Change your conservation methods.
All the above options reduce operating comfort as well as water usage.
2009 GMC 2500HD Crew Z71 / 3.73 / 6.0L
2012 Prime Time Lacrosse 318 BHS Touring
Reese WD System with HP Dual Cam
Factory GMC Brake Controller
Factory Receiver Hitch
Factory Tow Mirrors
On theProwl
Nicholasville, KY
Don't know that i can help with your usage, but i will say this. We just purchased a 2012 Jayflight 32 BHDS about a month ago. We have only camped once where we had to use the fresh water tank and pump, but this camper (pump) sure seems to have alot more pressure than our last camper. Thus, alot more water could be used if you dont watch the flow.
2012 Jayco Jayflight 32 BHDS
2006 Dodge 2500 Quad Cab 4x4 5.9 Cummins w/3.73
skipnchar
Topeka or somewhere else
You don't HAVE to turn faucets all the way on to use them.
pnj442
Cedar City, Ut
lushy wrote: I just purchased a 2011 Jayco Jay Feather Select 29L and I noticed that I am going through water much faster compared to my last TT. We are not doing anything different, as far as water usage, and we seemed to go through the water much faster?? I know my fresh water is a little smaller, 28.5 vs. 36 gallons, but I have taken that into consideration already. I am thinking that it may be the kitchen faucet or shower head? Is there a way to cut back on the water flow/usage without buying new faucets? Thanks.
Your new tank is almost 21% smaller than your old one.
BigSur2
Hampton, VA
I partially open my faucets...and I take navy showers. My FW tanks will last me 4 days if I conserve.
BigSur2
2012 Keystone Bullet 286QBS
2006 Ford F150 5.4 V8
lushy
N.W. Indiana
Thanks for the suggestions and info.
Phathead
tn
Just come from Ohio hunting trip. 32 gallon tank 5 navy showers commode flushing and minimum dish washing since I was in the woods during daylight hours. I dranied the grey in bucket and dumped in a hole on the landowner property (with permission of course) and it was approx 12 gallons.
