RV.Net Open Roads Forum: Class C Motorhomes: V10, 6.8 L Fuel Consumption
 > V10, 6.8 L Fuel Consumption
the trippers
Sandy, Utah
Posted: 11/04/11 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
It takes energy from the engine to make the electricity to break down the water into hydrogen and oxygen gasses, at least as much as the engine gets back minus losses, so no gain.
Also, hydrogen gas mixed with oxygen, unless safely contained is explosive.
2011 Jayco Greyhawk 31DS, 2-slides, 32" LR TV, 3-Cameras, Helwig Springs, Full Private Bath, MBR w/doors, 2 Dogs - Collie & Poodle, retired for the 3rd time.
rjstractor
Auburn, WA
Posted: 11/04/11 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, but no more so than propane or gasoline.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
2006 Ford Escape Hybrid
1998 Saturn SL2 toad
2012 VW Jetta S
modmidget
Woodland, CA
Posted: 11/05/11 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I've played around with a couple of hydrogen generators. One of the "by-products" from the generator is water. Water can rust your pistons, cylinders, and exhaust system. To protect your engine's internal parts from rust you would probably have to put some kind of ceramic coating on everything.
To some it's a six pack, to me it's a support group.
Jpjlauer
ELKHART, IN
Posted: 11/06/11 08:23am Link  |  Quote  |  Print  |  Notify Moderator
When my 2006 30' Gulfstream BTCruiser was new in 2005 I got 9.0 mpg so consistently that I stopped checking.
Two years later I started towing a Honda CR-V and I began checking mileage again. Mpg dropped to 8.5 and was so consistent for about 10,000 miles I again stopped checking.
But I had discovered that I could expect about 100 miles for every 1/4 tank of gas per the gas gage.
This past year of travels (winter trip from Indiana to So Cal and summer trip to the Pacific NW) I began seeing only 85-90 miles per 1/4 tank so I checked mileage again. It has dropped into the low 7's!
Both going West and returning East.
I'm currently at 87,000 miles and I understand a tune-up is not "scheduled maintenance" until 100,000 miles. Does my drop in mpg sound like a tune-up is needed (probably very expensive) or is there something else I might not be aware of? Anyone else having the same experience? I did change tires to Michelin XPS Ribs two years ago, but I can't believe it would lower my mpg.
Engine seems to run just fine. I change oil and grease the zerks every 3,000 miles and have performed all scheduled maintenance. And I weigh before each trip to ensure I'm not exceeding the GVWR.
Any ideas?
Jim Lauer
2006 BTCruiser
2007 CRV tow
Jpjlauer
ELKHART, IN
Posted: 11/06/11 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Any ideas?
johnwb
Posted: 11/06/11 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 Winnei, Aspect 26A with a Ford V10 and get from 8 to 9.2 MPG on average. If I idle a lot or use the genny for any length of time, the MPG ticks down slightly. I've tried different speeds from 60 to about 68 mph on the Interstate and found that 60 or slightly under does best for me.
I have a very distant relative in Montana that claims he is using the hydrogen/oxygen from water gadget that he has made and gets "REALLY FANTASTIC" fuel mileage on his PU and actually sells the to 18wheeler drivers. I've asked him twice to send me the schematic so I can build one. Naturally I've never received it--It mysteriously gets lost in the mail. Yea, right.
sccamping
SC
Posted: 08/05/12 11:41am Link  |  Quote  |  Print  |  Notify Moderator
This may be in the wrong place but I've been searching for this topic:
which performs best and gives the best mpg Ford V-10 or the GM 8.1. I understand GM is not making that engine for the class A's anymore but we are looking at used units.
Thanks everyone.
Bruce & Chrissy
Kit Carson
Northwest Louisiana
Posted: 08/06/12 07:19am Link  |  Quote  |  Print  |  Notify Moderator
IMHO, you can't have a motorhbome with a V-10 gas engine and expect excellent or even good MPG. It is what it is!!! I agree with there not being a shorage of oil in this country and we should be more concerned about the high cost of fuel. There is something wrong somewhere.
KIT CARSON
GOOD SAM LIFE MEMBER
USAF VETERAN
ARS: KE5VLE
NORTHWEST LOUISIANA
bukhrn
Lanexa, Va
Posted: 08/06/12 09:55am Link  |  Quote  |  Print  |  Notify Moderator
rr2254545 wrote:
Raymon wrote:
rr2254545 wrote:
moderator notified
For what reason? Please explain. Thanks.
Ray
First post and pitching a product - this seem to me to be a attempt to sell us something.
I saw NO reference to the OP selling anything, only that He had bought a product, & his results from having done so. I didn't see any attempt to sell you anything.
And thanks to the OP for the info & trying to help us all.
2007 Forester 2941DS
2005 KIA Spectra
pnichols
Santa Cruz Mountains
Posted: 08/06/12 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Isn't the V10 engine in a lot of pickup trucks?
How does it's gas mileage in these Ford pickups compare with the gas mileage of similar horsepower V8's in Chevy and Dodge pickups?
Phil, 2005 E450 Itasca 324V Spirit
