pjhootch
Iowa
Hi all,
I'm visiting from the Class C forums, and need a little info for my neighbors.
They have a new to them Fleetwood American Tradition 40 DP, and haven't been able to get their water heater to work. My husband is going to go over and help them troubleshoot it tonight, since they are heading back to Florida early in the morning.
Since they bought it in florida about a month ago and had to have it "de-winterized" right before they took possession, my guess is they actually still have the water heater by-passed for winterization. Since we have a Class C Winnebago, we aren't completely clueless, but can someone give us some ideas about where to start looking for the WH by-pass, or any other trouble shooting ideas?
Thanks,
P.J.
2006 Winnebago Outlook 31C
Valkyriebush
Yuma/Port Townsend
Make sure any other source (outside shower with hose button) hot water spigot is shut off. I found this out from other forum members. Is it lighting on gas?
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
sch911
Rochester Hills, MI
The water heater bypass valves are almost always on the back side of the the heater itself. Find it on the outside of the coach, figure out which cabinet it's hiding behind and look inside!
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
skipnchar
Topeka or somewhere else
IF they've been running the water heater with it in bypass mode it may not do any good to open it up now as the electric element is more than likely gone by now. It will probably have either a single valve or a double valve system so if ht has two both will have to be correctly set. One line allows cold water into the tank and the other valve closes the bypass line that goes around the tank.
Good luck / Skip
rvsatek
AZ, USA
Your bypass valves could be on the back side of the water heater as most RVs are this way. But on your big class A you may have valves built into your water closet in the basement. If so they should be clearly marked "water heater bypass" . Those are the only two places I have seen them with a couple of rare exceptions.
Larry
1994 Ford F250/7.5L/410 gears
2001 Keystone Sprinter 276RLS 14' slide
Grey Mountain
On the rez somewhere in Indian Country
On my 2006 Discovery, the control lever is under the sink in the bedroom.
GM
Discovery 39S Tin Teepee
Honda CR-V Toad
Jeep Cherokee Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
pjhootch
Iowa
Thanks for the ideas everyone. It was even simpler than that. They didn't know there was a switch to run it on auto or from propane.
I guess they took delivery of it so quickly there wasn't time for a walk through. These folks are completely new to any kind of RV and are learning as they go.
We went in with them last night after I posted and showed them the basics that we know about. They've got about a million more buttons and controls then our 2006 Winnebago but the basics are the same.
Thanks again.
