RV.Net Open Roads Forum: Class A Motorhomes: Electrical Issue
 > Electrical Issue
Jesse735
SC
Posted: 11/05/11 05:50pm Link  |  Print  |  Notify Moderator
The starting battery on my rv was dead, so I de wides to utilize my car to jump start the mh. I connected the cables in reverse(pos to neg etc) now I am unable to get any power to the ignition switch. When you put the key into the ignition the usual light on the dash do not illuminate when you first turn the ignition switch. I am sure I shorted something. How should I go about trouble shooting this issue?
Jesse735
2000 National RV, Surfside 32'
Wife & Three Boys 14,12,6
Kiwi_too
Western, WA
Posted: 11/05/11 05:54pm Link  |  Print  |  Notify Moderator
First of all, jumping a 12v system from another 12v system is connected pos to pos and neg to neg. Check your fuses.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
Jesse735
SC
Posted: 11/05/11 06:07pm Link  |  Print  |  Notify Moderator
Would that be the fuses on the power distribution board or under the dash? I have jumped this unit many time when it has been idle for a while but just made a careless mistake!
barlow46
Edgewater, FL
Posted: 11/05/11 06:19pm Link  |  Print  |  Notify Moderator
Are you sure you don't have a "dead short" in your battery and no power at all? Did you try the jump start again with the cables correctly attached? Try disconnecting your starting battery and connect directly with your jumper battery. Don't try to start it, just turn on the key and see if the dash lights up.
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
Wherever I happen to park
Posted: 11/05/11 06:54pm Link  |  Print  |  Notify Moderator
With any luck at all.. The very expensive alternator will survive.
However.. I'd not count on it.
(That applies to the one on the car too)
rvsatek
AZ, USA
Posted: 11/05/11 07:15pm Link  |  Print  |  Notify Moderator
You most likely blew the ignition fuse. It is with all the other chassis fuses not the DC dist. panel.
Larry
1994 Ford F250/7.5L/410 gears
2001 Keystone Sprinter 276RLS 14' slide
Fulltimers
Anywhere, USA
Posted: 11/05/11 10:15pm Link  |  Print  |  Notify Moderator
The bad news is you probably fried your PCM (Computer).
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad)
Photos
kaydeejay
SE Michigan, USA
Posted: 11/06/11 03:06am Link  |  Print  |  Notify Moderator
Jesse735 wrote:
The starting battery on my rv was dead, so I de wides to utilize my car to jump start the mh. I connected the cables in reverse(pos to neg etc) now I am unable to get any power to the ignition switch................
By connecting reverse polarity I suspect you have blown MOST of the electronics in the RV. This could get VERY expensive if the engine computer is part of the damage.
Why oh why did you think you have to connect positive to negative etc
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
YC 1
Yuba City Calif.
Posted: 11/06/11 08:35am Link  |  Print  |  Notify Moderator
After the sparks flew have you tried to jump it with the correct polarity?
If not put the cables on it and charge it for 20-30 minutes before turning the key. The dead battery might have gone to nothing or even reversed polarity. Not likely. If things don't light up after 20 minutes then look for your fuse panel and check all fuses.
If you cannot find a blown fuse you need a test light or voltmeter. Often there is a "fusible link" a short distance from the battery that is designed to blow under certain conditions.
As for worrying about alternators and computers right now I would not sweat it. I would bet there are reverse polarity diodes in the computer designed to blow fuses before killing the computer.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
 > Electrical Issue
