RV.Net Open Roads Forum: Travel Trailers: Uneven Heating in TT
 > Uneven Heating in TT
harold1946
Surprise Arizona
Posted: 11/08/11 06:05pm Link  |  Print  |  Notify Moderator
Tell me why the ductwork into the holding tank area would not be considered when computing the area.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
LarryJM
NoVa
Posted: 11/08/11 06:15pm Link  |  Print  |  Notify Moderator
Because at least the Atwood SM clearly states and the following is a quote direct from their SM ....
Use of 2" ducts does not count towards achieving minimum discharge requirements. Ducting in dead air space with no return, such as holding tank areas, does not count toward achieving minumum discharge requirements
I think you can download this manual at Bryant RV, but I'm not going to try and educate you further and will leave you to do some homework here to become familiar with what manufacturers require. I'm not a HVAC engineer so all I can do is to following their instructions as you should when posting and not making stuff up.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
harold1946
Surprise Arizona
Posted: 11/08/11 06:28pm Link  |  Print  |  Notify Moderator
Guess all of those we have done in the past are not working. I wonder why we have had no complaints?
Evidently you have not read all of the posts or you would understand whats going on. There are many ways to achieve a balanced system including adding ducting, redirecting flow, internal baffels and duct sizing. If that is not understood i cant help.
Huntindog
phoenix arizona USA
Posted: 11/08/11 07:13pm Link  |  Print  |  Notify Moderator
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
harold1946
Surprise Arizona
Posted: 11/08/11 07:22pm Link  |  Print  |  Notify Moderator
Just as I thought, you realy don't understand.
Huntindog
phoenix arizona USA
Posted: 11/09/11 03:10am Link  |  Print  |  Notify Moderator
Manual? Manual? What's a manual? You mean theres a manual? Are you supposed to read the manual? Why read the manual?
That takes too much time and makes my head hurt. I'd rather just do it my way!
Sean Boburk
Posted: 11/10/11 08:03am Link  |  Print  |  Notify Moderator
I think our bunk house mattresses have heaters built into them...not sure how expensive it would be to replace mattresses with heated ones.
2011 Flagstaff 29SKBS
2010 F-150 4x4 5.4L
2011 camping days=23 in 9 locations
2012 camping days=4 in 2 locations
LAdams
Northern Illinois
Posted: 11/10/11 08:44am Link  |  Print  |  Notify Moderator
OK - we heard enough on this topic - post closed
Moderator - TT Forum
