RV.Net Open Roads Forum: Travel Trailers: Replacing shower knobs
 > Replacing shower knobs
WAgal
Sparks, NV
Posted: 11/08/11 12:53pm Link  |  Print  |  Notify Moderator
The shower knobs in our trailer are super touchy. If we aren't bumping them then the shower head hose is. My husband tried to see if the front caps came off so that he could tighten them but if they do it's not very easily. Can the knobs be tightened or replaced? We are going to be living in out TT for awhile now and this is one annoyance that would be nice to fix. Thanks!
2001 Ford F150 4X4 ext. cab 5.4 V8 Triton
2010 Keystone Cougar 25RLSWE
wa8shc
Parma, Ohio
Posted: 11/08/11 02:18pm Link  |  Print  |  Notify Moderator
The H/C plates on my were removable by prying on them slightly, just like a home faucet.
Use caution to not break them if they are 'original'. When mine broke, I couldn't find replacements that fit, and ended up replacing entire faucet assembly
JMHO
Denny WA8SHC and Rita WB8TIR
Siberian Husky Ta'kya (Princess RIP 10/04 Taz RIP 5/12/08)
2007 Dodge Ram 2500 Quad Cab 5.9L CTD 3.73/LSD,Quadzilla RECON monitor
2008 Rockwood 8243S 5th wheel
Pullrite 14K Superglide & MorRyde pinbox
WAgal
Sparks, NV
Posted: 11/08/11 07:12pm Link  |  Print  |  Notify Moderator
JMHO
My husband was worried they would break so he didn't keep at it.
jbbrick
Near San Francisco
Posted: 11/08/11 07:46pm Link  |  Print  |  Notify Moderator
What do you mean "touchy"? Do they get loose or does the water temp change? Most knobs have a cover plate on the end that pops off, or a screw in the side to release the knob. Look for one of those. If the temp changes, open it up and change the washers, which may help especially on the hot side.
'02 Winnie Adventurer 32V
2010 Ford Escape toad
WAgal
Sparks, NV
Posted: 11/09/11 11:06am Link  |  Print  |  Notify Moderator
If you barely touch or bump them they move and the temp changes. same thing if the hose touches them. It doesn't take much to move them. Last night DH did get the face caps off and tightened them and they are a bit better. Felt like they "loosened" up again though once the water was on. He will try tightening them again with the water running to see if that makes a difference.
