Well I thought that I had it all figured out. Just do what the manual says, but when I went to put the jacks down to level by pushing the auto. level button, by just turning the ignition switch on without starting eng. the slides went out automaticly, then the jacks went down witch is backwards from what the manual says(jacks are hyd. and are LCI on a Frightliner chaiss and the unit is 2009 Coachman Cross Country fws). Have not camped with it yet so still on a learning curve. Is this right or do I need to have it checked out or who could I call to make sure this is right?
On my Monaco when I stop, I check and close to level in manual mode, shut off engine, put out slides, turn key back on(do not need to start), hit auto-level and make sure DW does not move around until level.
Thanks for the response. This just bugged me just had to know why,so went back out to camper to run the slides back in and found that the switch that you hold while you operate the slide was stuck so that meant that when the hyd. pump ran the jacks it would run the slide.
LennyH wrote: What came first the chicken or the egg, First Level then sliders
Happy RVing
NOT, if you are driving a Monaco product.....
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever" '05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back. Where the wheels are stopped today
