CARBONE
Salem, NH
Just got a 4G MiFi (4510L, and It works great on my laptop with Vista and one with 7, but It will not work on my desktop with XP, any help out there
Thanks
AL
LittleBill
Scranton, PA USA
u have a wireless card in the desktop right?
CARBONE
Salem, NH
little bill
YES
sch911
Rochester Hills, MI
Need to make sure the wireless card in the XP machine supports the protocols and the levels of security needed. Many legacy PCI cards cannot do WPA2 for example.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
MitchF150
Washington, the State
I got 3 of these for my office staff to use while out in the field. Tested them on an old (4 years) laptop with XP on it. Worked fine.
Do you even see it on the available WiFi list to connect to it?
Or does it not connect after entering the pw? If that's the case, what sch911 says is probably the case....
Good luck!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
ReadyToGo
Minnesota
Mine works but I had the mifi before. Just click the name, key in the password, click always connect and away you go.
wittmeba
Virginia
Check the security of your router and the mifi. I just had the same a week ago on test. Just make sure they match based on the oldest O/S desktop settings.
See this:
http://www.rv.net/forums/index.cfm/fusea........thread/tid/25535494/gotomsg/25542079.cfm
More chit-chat here:
- Check the desktop
- Tweak the Router
- Match the Mifi
It was awesome, but the 10GB limitation would have put us in the poor house.
edited 11/09/11 07:37pm by wittmeba *
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 01/12/2013
louiskathy
Oregon (presently)
I'm thinking firewalled. Go to ...
Start,
Control Panel,
Network connections...
and see if it says "connected, firewalled"
Then check your exceptions. Go to...
Start
Control Panel,
Windows Firewall... and then look at the EXCEPTIONS tab.
If you have to... add it to the exceptions list and it should be able to connect and still be firewalled.
Still not sure whether it's the problem or not???
Turn your firewall off and see if you can get it to connect.
Kathy
Earl E
Green Valley, AZ
Mine runs fine on my XP. So the problem is in the set-up and I'm helpless in that area. But should not be a problem.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel-for sale now that we are not full-timing
2011 Keystone 23rks Hideout to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
mlts22
Austin, Texas
You will need to search and find a package from Microsoft to install on XP to get it to work with WPA2.
