I sent you the pics.
The lower connector goes left (to the lance connector/truck)
the upper goes right and to the circuit breaker on the board/camper batts)
White is ground.
Starter signal and starter lamp are not used on mine. Maybe that's my problem?!?
One post is labeled MAIN, the other is labeled AUX. I connected my camper battery to the AUX, and the truck/plug to the MAIN. They state that the AUX disconnects from the MAIN when the MAIN drops to 12.5-12.9. Is this correct?
My photos: http://mikekazphotography.com/Gerry/GalleryIndex/index.html
I just recieved my seperator 1314a. To change it out ,can I just push disconnect switch for camper? Or do I have to lift camper and disconnect camper plug to truck? Also how do you identify main cable to truck? Maybee I will be able to tell when step is taken off on my 1191. Thanks.
gkas wrote: One post is labeled MAIN, the other is labeled AUX. I connected my camper battery to the AUX, and the truck/plug to the MAIN. They state that the AUX disconnects from the MAIN when the MAIN drops to 12.5-12.9. Is this correct?
That is correct.
Main = Truck
Aux = Camper
I just wish mine worked! I'm pulling it out now. Hoping my battery charger will make 13.x volts with a motorcycle battery to test the operation.
