RV.Net Open Roads Forum: Truck Campers: Lance isolator recall question
 > Lance isolator recall question
kehale
Arizona 2011
Posted: 12/12/11 07:12pm Link  |  Print  |  Notify Moderator
I sent you the pics.
The lower connector goes left (to the lance connector/truck)
the upper goes right and to the circuit breaker on the board/camper batts)
White is ground.
Starter signal and starter lamp are not used on mine. Maybe that's my problem?!?
06 Lance 1181
gkas
Posted: 12/14/11 06:48pm Link  |  Print  |  Notify Moderator
One post is labeled MAIN, the other is labeled AUX. I connected my camper battery to the AUX, and the truck/plug to the MAIN. They state that the AUX disconnects from the MAIN when the MAIN drops to 12.5-12.9. Is this correct?
My photos: http://mikekazphotography.com/Gerry/GalleryIndex/index.html
kehale
Arizona 2011
Posted: 12/14/11 07:18pm Link  |  Print  |  Notify Moderator
That is correct.
Main = Truck
Aux = Camper
I just wish mine worked! I'm pulling it out now. Hoping my battery charger will make 13.x volts with a motorcycle battery to test the operation.
pa traveler
usa
Posted: 12/15/11 05:28am Link  |  Print  |  Notify Moderator
I just recieved my seperator 1314a. To change it out ,can I just push disconnect switch for camper? Or do I have to lift camper and disconnect camper plug to truck? Also how do you identify main cable to truck? Maybee I will be able to tell when step is taken off on my 1191. Thanks.
JumboJet
Tontitown ARKANSAW
Posted: 12/15/11 06:58pm Link  |  Print  |  Notify Moderator
kehale
Arizona 2011
Posted: 12/15/11 11:54am Link  |  Print  |  Notify Moderator
How does one install a battery in a car? Just connect it in.
The lug for AUX should be going to a circuitbreaker with a bunch of other stuff on it (big black wire)
The MAIN wire comes from the penetration (lance cord) plugging into the truck bed.
The ground plugs in the long buss bar (white wire)
That's it.
Still can't make mine work! argh!
