This season, our flush ball started leaking the bowl dry. I cleaned it good and it worked for the rest of the season, but now it won't seal at all. The ball closes, just won't hold water very long. I saw somewhere that turning the ball seal to a different spot will allow it to make a new micro scratch pattern and will probably fix my problem for a year or so. Anyone have experience with this? Looks like individual parts are not too pricey, but complete rebuild kits run into $100 + dollars.
Sunset Creek 298 BH
My toilet did that. I put olive oil in toilet and let it sit a few weeks. That was over a year ago and problem has not returned. Might be worth a try?
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories I can't be lost because I don't care where this lovely road is going
I'm subscribing to this thread to find an answer.I cleaned the groove with a coat hanger, still leaked. I tried the vegetable oil, motor oil, vaseline the seals trick, no dice. I replaced the seal 6 months ago ($36!) and it started leaking again last week. Took it completely apart, completely cleaned the seals and grooves and it held water for another 3 days. If this is typical of an expensive, porcelain bowl toilet, I'm going back to the cheap plastic Thetford!
On Edit: Thanks for the cheap seals link Bob! That might be feasible.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
I need to use vinegar sometimes because of the water in Az. this cleans off the mineral from the rubber seal and cleans the ball. It has been good since we left washington st sept 28th. I used mineral oil in the toliet during the summer months.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
larry barnhart wrote: I need to use vinegar sometimes because of the water in Az. this cleans off the mineral from the rubber seal and cleans the ball. It has been good since we left washington st sept 28th. I used mineral oil in the toliet during the summer months.
chevman
"Vinegar, Oil"?!? It's a Toilet bowl Larry, not a salad bowl!!
I have a sealand flush ball and shaft kit #385318162 that doesn't fit my toilet. If someone can use it send me a PM and you can have it. Fits 106,111,131,206,208,248,306,308,348,506,508,510,511,547,548,557,558,606,706,711m28,712,806,847,848,906,908,910,911,911-28,911-36,980,1006,1008,1047,1048,1049,1088,1106,1606,2010,2011,5006,5706.
