maryvillept
Jackson, MO
Ok I'm in the market for a 5th wheel toy hauler. Found one that's 6 hours away that I'm very interested in when my truck comes in. What I need to know is the weight of the thing. It sounds like an older couple and they can't find it anywhere on the rv. It's a 2002 New Vision by Sportmen (KZ production). I believe it's model m-35-power. It's 36' triple axle with bedroom and living room slides.
My question, does anyone have this model if so what's the loaded and unloaded weight?
If no one has that model, what's your weight if you are similarly equiped (36' triple axle, 2 slide)(I know it's going to vary a lot but just go with it lol)
edited 11/11/11 06:42am by an administrator/moderator *
2012 Chevy 3500hd crew cab short bed. 6.0 L, 4x4
16k Reese slider hitch
2007 Forest River Salem 38' toy hauler
4*phun*2
Canada
Probably upper limits of a 250/2500. Easily hauled by 350/3500.
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
jetboater454
Camping or home
Similar to this. Clicky
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
maryvillept
Jackson, MO
Hey jet, I saw that one but its not a toy hauler. I figured weights will vary quite a bit.
baker01
Ridgecrest/Inyokern
Found this
2002 m-35
kaydeejay
SE Michigan, USA
If you are looking at towing with less than a high capacity* SRW 1-ton truck, you need to take a very close look at the LOADED pin weight of the fiver vs the truck payload remaining after deducting the weight of occupants, hitch, fuel and other stuff.
A 13,500# GVWR fiver will typically have a 2700# pin weight and is probably beyond the capacity of most 3/4 tons, some of which may have a TOTAL payload as low as 2100#.
* A post 2005 Ford/2010 or later GM would fit this category.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
maryvillept
Jackson, MO
I ordered a 3500 chevy crew short bed SRW. 6.0 gasser with 4.10. Pinweight no issue. Just want to make sure gasser will pull okay.
Mmaxed
Montana
I tow a 34' Fuzion 302 with a F250 with a V10 gasser. The hauler is at the limits of the 3/4 ton in my opinion. The biggest thing you need to watch out for is the weight on the rear tires. The gasser should handle it OK. I tow in mountains and wind and always get there, just not quite as fast as I would with a smoker.
John & Angela
Full Timers in Canada, USA and Mexico
190. 6'1". handsome as hell.
2003 Revolution 40C Class A. 2002 Vanguard 22 foot Class C. Diesel smart car Toad or pulling a 2009 Timeout Tent Trailer.
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
kaydeejay
SE Michigan, USA
maryvillept wrote: I ordered a 3500 chevy crew short bed SRW. 6.0 gasser with 4.10. Pinweight no issue. Just want to make sure gasser will pull okay. OK, your MAX tow rating is between 13,700# (4WD) and 14,000# (2WD). Those numbers only apply to a truck with a 150# driver aboard. They will be reduced depending on how many more people and/or "stuff" you have in the truck.
If you load that trailer up to GVWR you could actually be a little over your Max trailer rating. Your truck will be working hard in the mountains, otherwise I don't see a problem.
