RV.Net Open Roads Forum: Tech Issues: Insulate propane tanks/lines/regulator for high altitude?
 > Insulate propane tanks/lines/regulator for high altitude?
dougrainer
Carrolton, Texas
Posted: 11/13/11 04:22pm Link  |  Print  |  Notify Moderator
christopherglenn wrote:
They are painted white, and most are covered for a reason. You don't want to overheat them in the summer, and cause them to vent propane.
As long as they are filled properly (by weight), then there is room for expansion due to higher ambient temps. Doug
christopherglenn
a little over an hour from Yosemite
Posted: 11/13/11 06:31pm Link  |  Print  |  Notify Moderator
If they are filled, by whatever method you choose, and are painted black, in the summer sun, the tanks will easily exceed 140-160 degrees (based on the temps that my spare hitch, painted black reached sitting in summer sunlight). There is not enough room for the propane to expand without venting at those temps.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
dougrainer
Carrolton, Texas
Posted: 11/13/11 06:56pm Link  |  Print  |  Notify Moderator
The ONLY correct method is by weight, not volume and as I stated, IF filled correctly will NOT vent due to high ambient temps. IF you find a filler that fills by volume and uses the 80% valve to spew liquid, then the tank is already overfilled. IF you are experiancing a problem with venting in those temps, then you need to verify CORRECT by weight filling. In Texas, by LAW, you can only fill by weight which is the National gas code also. We had 115 ambient this summer and NONE of the tanks we had filled for all our sold trailers ever spewed. That was easily 400- 20 and 30 lb tanks. AND, we had NO customers calling complaining about tanks spewing. Because, they are filled correctly by weight, which allows expansion in the tank. Doug
texasrat
Las Crusas, NM USA
Posted: 11/13/11 07:25pm Link  |  Print  |  Notify Moderator
interesting chart
Vapor pressure in psi (bar) of propane vapor at temperatures ranging -30 - 110 oF (-42 - 43 oC)
Temperature
Vapor Pressure
(oF).....(oC)...(psig)..(bar)
-44.....-42.2...0.......0
-30.....-34.4...6.8.....0.5
-20.....-28.9...11.5....0.8
-10.....-23.3...17.5....1.2
0.......-17.8...24.5....1.7
10......-12.2...34......2.3
20......-6.7....42......2.9
30......-1.1....53......3.7
40.......4.4....65......4.5
50.......10.0...78......5.4
60.......15.6...93......6.4
70.......21.1...110.....7.6
80.......26.7...128.....8.8
90.......32.2...150....10.3
100......37.8...177....12.2
110......43.3...204....14.1
* This post was edited 11/13/11 07:43pm by texasrat *
pianotuna
Regina, SK, Canada
Posted: 11/13/11 07:39pm Link  |  Print  |  Notify Moderator
Hi,
Here is a link to the chart:
propane vapor pressure
And a graph:
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
ejforwood
Littleton (Denver) Colorado
Posted: 11/14/11 01:18am Link  |  Print  |  Notify Moderator
Bionic Man wrote:
Lived and camped in Colorado all my life. I have spent many camping trips above 9000 foot. Never neded to make changes to get the propane system to work.
X2
Have hunted deer and elk above 10k for many years. The propane griddle and range we used in our 12 man tent always worked great!
We always leave the tanks outside in the snow and often -0 weather.
* This post was edited 11/14/11 12:49pm by ejforwood *
Jerry & Dottie
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
Dave H M
IL
Posted: 11/14/11 05:21am Link  |  Print  |  Notify Moderator
Oh man, now have to take the propane tanks to bed with me along with the batteries.
profdant139
Posted: 11/14/11 11:44am Link  |  Print  |  Notify Moderator
No, Dave -- the tanks and the batteries will have the bed, and I will sleep on the floor.
Our trips -- pix and text
About our trailer
