I have a new 2011 Cougar 328 and the Rubber "Flap" Gaskets are coming loose on my bedroom slide. And instead of taking to the dealership for 2 weeks for them to repair, what can anybody recommend i use to re-glue the Rubber back onto the frame?
Thanks
Garett Kaiser
www.amatuber.com
2005 GMC 2500HD D/A 6.0 3.73 CC SB 4x4 running Schaeffer Synthetic Lubricants from Axle to Axle.
2011 Keystone Cougar 328QBS
2001 Mako 171
www.amatuber.com
If you are careful, a double sided glue such as Contact Cement will work fine.
Be aware that when applying the glue to the RV and to the seal, and waiting till nearly dry, THEN when the rubber is placed against the RV it will bond instantly (and I mean INSTANTLY!) and stay put. It has to go right where you want it on the first try!
Again, it's imperative to work carefully because it will stick when it is put..period!
Note that if you do this without involving the Dealer, all further warranty claims for the seals is voided.
If you need to attach a gasket or the like and have a 1/2" wide surface you can use 3M automotive trim tape available in most chain auto stores. Once this stuff sticks you won't get it off. Not your normal double faced tape. Here is a link to show you what I am talking about.
First use the warranty if you can but sometimes it is not possible to drag your trailer to a dealer. This would be my next choice over any liquid, you can control where this goes.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ HTT Mods
Take it back to the dealer as the slide may not be aligned correctly and that's what made the seal come loose. Better yet take it to the factory service center if that's possible.
I would expect that the seals attachment would be considered a warranty item on a 2011 model year trailer. I'd think about letting THEM withstand the liability of reattaching your seal.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR - 2004 F-150 HD (Traded after 80,000 towing miles) 2007 Rockwood 8314SS 34' travel trailer
