Friend has 2005 Winnabago, Journey, on Freightliner.
Turn Signals and Flashers do not work. Other lights, brake and running work. He needs to know where to look for fuse of relay.
Thanks for your help.
Fuses are in front behind metal panel and are marked. If it is not a fuse then check the flasher relay (there are two of them, one for directionals and the other for flashers). They are located behind the steering column. You will have to lay on the floor to see them.
Terry and Kim Streit
2002 Itasca Horizon (El Gordo)
2012 Jeep Wrangler (Paco)
Life is Good
