StevenMarla
Reno, Nevada
My new Moho is parked in from of my house and we've got high wind warnings, 60+ mph. The moho is rockin and not in the good way so I powered it up and dropped the levelers. State of emergency declared everywhere. A lot of it is due to a huge fire that burned 20 homes.
PapPappy
Wilmington, NC
Can you just leave the area? Maybe take the RV out of county, and park it at a Walmart or something, for the day/night?
Do they expect higher winds? A little rocking may not be good, but it's also probably not going to tip over either. Might be good, if you can park it next to a flat-sided building, so as to buffer any winds that might effect it in the open.
good Luck
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
StevenMarla
Reno, Nevada
Too windy for me to drive it. It is fairly level but the levelers equalized the Moho. It's no longer rocking. I didn't have the time to take it Rv storage yesterday where it would be parked between a similar size A and shorter C.
Winds are not expected to get stronger. Luckily no nearby big trees to fall on Moho or the house.
Old-Biscuit
Across the USA
"Might be good, if you can park it next to a flat-sided building, so as to buffer any winds that might effect it in the open".......
That's what I would do........block some of that wind. Otherwise....pull out your MH Ins. Policy and read the fine print.....just in case!
coolbreeze01
Redding, Ca
Should be fine as long as you aren't in front of the fire. Looks horrible there. Good luck.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
mockturtle
WA
If the wind is directional it will help to line it up with the wind, of possible.
2000 Born Free 24RB Class C
6.8L Ford V-10 Engine, E450 Chassis
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
I realize that it rocks less with the levelers down however the manual for our HR recommends against using them in very high winds to prevent damage to the system.
You might want to verify the manual for your unit.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
Fizz
Ottawa, Canada
Nose it into the wind, no different than driving at 60mph
Homer
Northeast Indiana
Nose or rear end into the wind if possible is the best immediate remedy. Jacks down is iffy. Lot of stress on mounts.
Jack Spratt
Maine
Homer wrote: Nose or rear end into the wind if possible is the best immediate remedy. Jacks down is iffy. Lot of stress on mounts.
And a quick call to your insurance agent
'11 GMC 2500 D/A 4x4
3455SA Montana
