RV.Net Open Roads Forum: Travel Trailers: I Found the Gray Tank Leak!
 > I Found the Gray Tank Leak!
Aluminum Siding
So Cal
Posted: 11/19/11 06:21pm Link  |  Print  |  Notify Moderator
I was reading pilot4net’s thread about his gray tank leaking and that he found at the tub. Mine has been leaking since I got it and it bugged the heck out of me. It would leak when it got full and it leaked off the top of the tank down on to the ground. I went in the TT and followed all the lines. The restroom sink drains to the black tank. The shower drains to the breather pipe which drains to the gray tank under/in the closet. The kitchen sink drains for a few feet under the cabinets and then connects to the top of the gray tank under the fridge. I wiggled that connection and it was completely broken. I tore the plate off the floor around the pipe and the threaded connector into the top of the gray thank had broken clean off. The busted thread piece was still threaded into the thank. I cut it out with a hack saw blade and it fell into the tank. I’m gonna have to take the drain pipe off to get the piece out. Otherwise it could restrict the water flow. The connection in the closet is also cracked. I’m so happy. About $10 at the Home Depot and It’ll be all fixed. I’m very happy with Fleetwood. My 94 Mallard is made so that I can easily get to everything in the event something breaks. I’ll post some picts of the fix when I do it.
pasusan
Northernmost PA
Posted: 11/19/11 06:49pm Link  |  Print  |  Notify Moderator
Good job!
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
*** Also a 2004 Roadtrek 170 (See pic in Profile) ***
Trip Pics
fla-gypsy
North Florida
Posted: 11/19/11 07:13pm Link  |  Print  |  Notify Moderator
Good work.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
hilandfrog
Montana
Posted: 11/19/11 08:40pm Link  |  Print  |  Notify Moderator
Aluminum Siding wrote:
....I wiggled that connection and it was completely broken. I tore the plate off the floor around the pipe and the threaded connector into the top of the gray thank had broken clean off. The busted thread piece was still threaded into the thank. I cut it out with a hack saw blade and it fell into the tank....
Have you thought about using rubber "slip" fitting as they don't require glue and they allow for movement and absorb vibrations from movement and the road....?
Repo
05 Tundra 4x4
1977' Road Ranger, Diddums is in action.
Aluminum Siding
So Cal
Posted: 11/19/11 10:32pm Link  |  Print  |  Notify Moderator
Repo
Now that's why I sighed up for this forum. I will totally use one of those. Never thought of it. This will make the job much easier especially in the breather I won't have to crack the caulking on the roof to lift the pole when I replace the one on the breather end. This will also allow for movement.
Thanks again. I'm going to do the job sometime this week so I'll post some photos. I figure at worst folks would like to see how the pipes connect to the gray tanks.
hilandfrog
Montana
Posted: 11/19/11 11:55pm Link  |  Print  |  Notify Moderator
Repo
I just bought 2 at our local RV place for $4.95 each, 1 1/2".
They have a "fat" end with a grove, the bottom of the grooved rubber fits inside, while the other is on outside of tank, I used dish washing soap to help "slip it in" to the tank and a little more to get the pipe in the slip.
Have fun on your project[emoticon]
Repo
Aluminum Siding
So Cal
Posted: 11/20/11 01:48am Link  |  Print  |  Notify Moderator
Repo
Repo
Can you post a link to a pict of what you used? Thanks Mike.
