RV.Net Open Roads Forum: Fifth-Wheels: Tires for my 5th wheel
 > Tires for my 5th wheel
Kayli's Papa
Washington
Posted: 11/20/11 08:48am Link  |  Print  |  Notify Moderator
I am concerned that the tires on my Jayco Pinnacle (Goodyear Marathon ST 235/80R-16 LR E) are not the right choise for a trailer that heavy(14,800 #) . I read a post some where that they may fail and the sugestion is upgrading to a G range tire. Any help will be appreciated.
jmtandem
western nevada
Posted: 11/20/11 09:30am Link  |  Print  |  Notify Moderator
I would weigh each axle to see how much load you are carrying with water, propane, batteries and generally loaded for camping. It might surprise you. Then address the tire capacity/reliability issue.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
powderman426
ohio
Posted: 11/20/11 10:21am Link  |  Print  |  Notify Moderator
Good info. Thanks.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
donn0128
Pronounced Ore-gun
Posted: 11/20/11 09:32am Link  |  Print  |  Notify Moderator
What axles do you have under your trailer? If they are 6000 pound axles or less any good LT truck tire will be sufficient. BFGoodrich and Michelin are top choices.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
dqdick
Council Grove, KS
Posted: 11/20/11 09:38am Link  |  Print  |  Notify Moderator
This was originally posted on some thread here and has been posted on many other forums since, but it answers your questions so here it is:
"Read the following and learn from this RV.net fellows research. MIKE
As we banter about regarding tire types and loading, I believe that we are finally starting to understand a few important things.
I have asked many times for someone to explain how a ST tire can be rated to carry more weight than a LT tire in a similar size, without a good answer.
The answer lies in what is called reserve capacity. To quote from Trailer Parts Superstore and this same statement exist on just about every tire site:
HEAVY DUTY 'LT' TRUCK / TRAILER TIRES
'LT' signifies the tire is a "Light Truck/Trailer" series that can be used on trailers that are capable of carrying heavy cargo such as equipment trailers.
If a tire size begins with 'LT' it signifies the tire is a "Light Truck-metric" size that was designed to be used on trailers that are capable of carrying heavy cargo or tow vehicles. Tires branded with the "LT" designation are designed to provide substantial reserve capacity to accept the additional stresses of carrying heavy cargo.
So what is reserve capacity? It is capacity beyond the rating of the tire, capacity that is held in reserve. This reserve capacity comes from the heavy-duty sidewall of the LT type tires. LT's rank at the top of the list when we look at P, ST and LT tires.
Now I finally have an answer to how a ST tire can be rated to carry more weight than a LT tire of similar size.
The ratings of ST tires infringe into the reserve capacity of the tire. This is double bad, because the design of the ST gives us a tire with less reserve capacity to start with as it has a lighter sidewall to start with as most ST tires are much lighter than their LT counterparts.
To quote one tire site:
"Put a different way, the load carrying capacity of an ST tire is 20% greater than an LT tire. Since durability is strictly a long term issue - and the results of a tire failure on a trailer are much less life threatening than on a truck - the folks that set up these load / inflation pressure relationships allow a greater......ah......let's call it load intensity."
There it is in print to be read. They make a calculated decision to give the ST tire a higher load rating because a failure is less life threatening.
I have on a number of occasions pointed out the weight difference between the different tires and have been told that does not matter. Well it does matter. The rubber in the average tire only makes up around 40 some percent of its weight, the rest is in the steel belts, gum strips, steel beads, and the carcass plies. The remaining 60 or so percent of the stuff in a tire is what builds in the reserve capacity.
So to review again, here are some weights:
1. Michelin XPS RIB LT235/85R16 LRE (rated to 3042lbs) Weight 55.41
2. Goodyear G614 LT235/85R16 LRG (rated to 3750lbs) Weight 57.5
3. Bridgestone Duravis R250 LT235/85R16 LRE(rated to 3042lbs) Weight 60
4. BFG Commercial TA LT235/85R16 LRE(rated to 3042lbs) Weight 44.44
5. Uniroyal Laredo HD/H LT235/85R16 LRE(rated to 3042lbs) Weight 44.44
6. GY Marathon ST235/80R16 LRE(rated to 3420lbs) Weight 35.4
So which tires on the list have the most reserve capacity? Well that is not a completely simple answer, as one of the tires is a G rate 110 lb tire and the rest are LRE at 80lb inflation. So if we disregard the G614, then the Michelin XPS RIB and the Bridgestone Duravis R250 due to their all-steel ply construction will have the most reserve capacity inherent in their construction. The twin Commercial TA and Laredo will be next and the Marathon would have little or no reserve capacity available because it was used up in its higher load rating, AND because of it's much lighter construction it had much less inherent reserve capacity to start with.
So what have we learn from this?
I think that the first thing that we learned was that a LT tire can be used at or near it max rated loading without having issues, as they built with "substantial reserve capacity to accept the additional stresses of carrying heavy cargo".
The second thing we may have learned is why ST tires are failing on mid to larger 5th wheels, in that they do not have inherent reserve capacity beyond that rated max loading. Again this is because they have less reserve capacity to start with and their greater "load intensity" used up any reserve capacity that might have been available.
Now, here is an interesting bit of information. I just called Maxxis Tech Line and asked the weights for two tires.
ST235/80R16 LRD 3000 lb rating at 65 lbs of air weights 38.58
ST235/80R16 LRE 3420 lb rating at 80 lbs of air weights 43.43
What??? The Maxxis load range E tire weights almost the same as the Commercial TA?? This is a ST tire that has heavier construction than the GY Marathon at 35.4 lbs. So it has more inherent reserve capacity due to its heavier construction.
Those that claimed its virtues maybe did not know why it was a better ST tire than some of the others, but there it is! It is a heavier built tire with more reserve capacity.
So as one chooses a replacement tire or is asking for an upgrade on a new trailer please get educated on where the reserve capacity exist. Is it inherent in the tire you choose or do you have to factor it into the weight rating of the tire you choose.
Those with heavy trailers that are switching to 17.5 rims and tires rated to 4805 lbs and getting a double injection of reserve capacity, in that they are using a tire with lots of inherent reserve capacity and the tire has much more capacity than the application. It is all starting to make sense.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
dqdick
Council Grove, KS
Posted: 11/20/11 09:43am Link  |  Print  |  Notify Moderator
When I bought my Montana and found out the many many instances of Marathons blowing up and damaging the rigs I called Goodyear. I asked for a supervisor, didn't get one, but when I explained that both I and Goodyear knew that Marathons shouldn't be on my rig and wanted to work out a deal with them to avoid issues for both of us in the future. I was put on hold several times. Made to haul my trailer to a Goodyear dealer (40miles one way for me) for them to measure wear and then we did a deal. My trailer was a 2010 bought this year but the Marathons were made in 09 so they used the 09 Marathon price but I still got 5 new G614's mounted and balanced for $825. Now I feel much more comfortable going down the road.
Markrving
Byers, Colorado
Posted: 11/20/11 10:36am Link  |  Print  |  Notify Moderator
Hi Kayli Papa,
This information compiled by Mike and stated from Dick is absolutely great! I learned the hard way about ST Marathons with $1200 worth of damage. I now have LT B.F. Goodrich Commercial TA. I do think you should have concern in my opinion. Happy Camping!
2010 Montana 3150. Chevrolet 2006 Duramax 2500 long bed 4x4 Michelin. B & W Companion. Goodyear Marathon Chinese Bombs gone, New B.F. Goodrich Commercial LT. Mark Allen
generaljean
Alpena, michigan
Posted: 11/20/11 10:50am Link  |  Print  |  Notify Moderator
Just put 4 BF Goodrich Commercial TAs BFG Commercial TA LT235/85R16 on my 5er (approx. 11,000# loaded). Leaving for Florida very soon--hope it was a good choice.
Denny & Jami
Home Base Nebraska
Posted: 11/20/11 01:41pm Link  |  Print  |  Notify Moderator
If it was me and the problems we have had with the GY G tire I would just spend the extra money and go with 17.5 H tires and wheels.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Sumitomo tires
cruz-in
Southern Maryland
Posted: 11/20/11 02:22pm Link  |  Print  |  Notify Moderator
Checking online you can get the 235/85/R16 Michelin Rib or Bridgestone Duracis for about $225 a piece plus shipping or the Goodyear G614 for about $350 per tire plus shipping.....
Any thoughts on why the Goodyear is so much more expensive? Is it a better tire?
