RV.Net Open Roads Forum: Dometic ref. not running after unlevel for 5 days
 > Dometic ref. not running after unlevel for 5 days
America_west
Washington
Posted: 11/20/11 06:05pm Link  |  Print  |  Notify Moderator
I had no choice but to operate my Dometic ref. for 5 days being unlevel about 3 inches. Now it only runs for a couple mins and totally shuts down. Do I have to leave it set level for a period of time, or will it need service or replacing? It's been level now for 4 days, and it still shuts down after a short period of time.
Ron
tvman44
Southwest Louisiana
Posted: 11/20/11 06:07pm Link  |  Print  |  Notify Moderator
Might be time for a new cooling unit because of blockage.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
mena661
Posted: 11/20/11 06:16pm Link  |  Print  |  Notify Moderator
My fridge is always unlevel when at home. I fire it up before a trip and run it for a couple days without leveling with no issues.
Trojan L16 6V's 740 Amp-hours
Old-Biscuit
Across the USA
Posted: 11/20/11 06:20pm Link  |  Print  |  Notify Moderator
Sounds like you may have 'no choice' but to replace it.
From your description the cooling unit has probably clogged from the unlevel operation. When unlevel and operated the 'coolant' flow can be blocked and then crystallizes from the heat clogging the cooling unit.
A reported fix is to remove refrigerator, turn it up side down for 24 hrs. and then reinstall......supposedly breaks up the clog and redistributes the coolant. But sounds like a temporary fix as crystals are still in system and will clog unit again.
Old-Biscuit
Across the USA
Posted: 11/20/11 06:23pm Link  |  Print  |  Notify Moderator
A little unlevel....no real problem
But 'unlevel' (several inches off level as OP stated)..you are running on borrowed time....and you have a fairly new unit. Hope you don't have to replace it soon
Wills250psd
walnutcove NC
The TT we have now the fridge will work out of level fine, the last 5er would not work unless level, you may have a problem, hope it dont cost much to get fixed good luck!! Will
sch911
Rochester Hills, MI
Posted: 11/20/11 07:01pm Link  |  Print  |  Notify Moderator
Jack_Diane_Freedom wrote:
I had ana Dometic do that a few years ago. I was told by a technician to take a large screwdriver by the blade and bang the 'U' returns on the outside of the unit to loosen up the crystalization. Worked fine after I did that.
I had that work once on an older unit also....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
zip0
NY
Posted: 11/20/11 06:25pm Link  |  Print  |  Notify Moderator
OK not sure if this will work but a few years ago I watched a guy in a CG do this. He took his fridge out of his TT, turned it upside down for a few hours, then flipped it back over and reinstalled it. He claimed that it will dislodge the blockages in the system. The next day he told me it was working like new.
Hey if you have to remove it to install a new cooling unit what can it hurt to give it a try first.
If you do and it works let us know.
" A day without camping is....WORK"
2003 Bounder 35R
3 Jack Russell's
Jack_Diane_Freedom
Milton Ontario Canada
Chuck&Gail
In the Colorado Mountains
Posted: 11/20/11 06:26pm Link  |  Print  |  Notify Moderator
Are you handy? Some folks have reportedly had good luck removing the fridge, turning it upside down, and leaving it that way for 24 hours, then reinstalling. Never tried it myself.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
