RV.Net Open Roads Forum: Dometic ref. not running after unlevel for 5 days
 > Dometic ref. not running after unlevel for 5 days
enblethen
Moses Lake, WA
Posted: 11/20/11 07:02pm Link  |  Print  |  Notify Moderator
Take it for a ride down a rough road. Of course, here in Washington you may have a problem finding one!
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
dougrainer
Carrolton, Texas
Posted: 11/20/11 08:01pm Link  |  Print  |  Notify Moderator
You need to explain better. HOW do you know it shuts down after a few minutes??????? It takes 24 hour for a refer to get to operating temp. Doug
JC2
Mo
Posted: 11/20/11 08:12pm Link  |  Print  |  Notify Moderator
America_west wrote:
I had no choice but to operate my Dometic ref. for 5 days being unlevel about 3 inches. Now it only runs for a couple mins and totally shuts down. Do I have to leave it set level for a period of time, or will it need service or replacing? It's been level now for 4 days, and it still shuts down after a short period of time.
Ron
Give the people in this link a call. You might be able to replace just the rear guts without having to buy a new box, etc.
http://rvcoolingunit.com/
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
enblethen
Moses Lake, WA
Posted: 11/20/11 08:15pm Link  |  Print  |  Notify Moderator
RVmobile.com
They are located in Everett. They do complete rebuilds. You must take refer to them.
Alpenliter
Fulltimer: Wherever we are!
Posted: 11/20/11 08:20pm Link  |  Print  |  Notify Moderator
Welcome to the Forum Ron. You didn't mention whether it stops working on gas and/or electric. Shutting down after a few minutes does not sound like a cooling unit problem. Sounds more like a circuit board, but I would recommend having the unit looked at professionally. Good luck and again, welcome to the forum.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
1Sammiedog
Posted: 11/20/11 08:26pm Link  |  Print  |  Notify Moderator
If you do find that the cooling unit is bad and will no longer work, you can order a new one from The Cooling Unit Warehouse and install it yourself. It's really not that difficult if your handy with tools. I recently replaced the cooling unit on my Norcold 1201 by myself and am quite happy with the end result. Here is a short video showing my Amish Cooling Unit Installation
1Sammiedog
America_west
Washington
Posted: 11/21/11 06:08am Link  |  Print  |  Notify Moderator
OK you guys. Thanks for all the responses. Here's the complete details: After the 5 days of being 3 inches unlevel, we are in a total level position. The unit ran fine while unlevel, but then using either gas or elec. the unit would completely shut off after maybe 20 mins. All lights would shut off and it would not start unless I started it manually. It would run for a few more minutes and shut down again. I let it set all night last night and tried to start it a few mins. ago. Both gas & elec. It shut down within 5 mins. No blockage of vents, Gas burns beautifuly, no odors, nothing leaking anywhere. I beat on the tubes with the handle of a big screwdriver as one fellow suggested to no avail. Calling a tech today. Thanks again. Ron
eHoefler
ozark mountains
Posted: 11/21/11 06:09am Link  |  Print  |  Notify Moderator
Take the trailer for a ride on a hilly winding road if possible. This will shake things up internally in the cooling system. When setting for a long period out of level, the coolant will separate and has a liquid gas block. The driving around will usually stir things back up if it has not set too long. If that doesn't work, removing and sitting it upside down over night usually will for stubborn cases
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
jetboater454
Camping or home
Posted: 11/21/11 07:06am Link  |  Print  |  Notify Moderator
If the lights go off,sounds like a power problem.You can also try a vibrating sander on the tubes to shake things up.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
hmknightnc
Wilmington, NC
Posted: 11/20/11 09:56pm Link  |  Print  |  Notify Moderator
x2. I don't know of any mechanism for the refer to know that a clogged unit condition has happened and shutdown the system within a few minutes. A clogged unit is usually detected by it not cooling down in several hours. Google your refer circuit board and follow the troubleshooting instructions. My guess is something in the circuit board or a bad ground.
You didn't mention if it shutoff using propane or electic. If it is propane then there are several other things to check. Let us know if that is the case
