RV.Net Open Roads Forum: Class A Motorhomes: Question about HDTV
 > Question about HDTV
dougrainer
Carrolton, Texas
Posted: 11/21/11 07:57am Link  |  Print  |  Notify Moderator
rgatijnet1 wrote:
dougrainer wrote:
rgatijnet1 wrote:
The HDMI cable is used to prevent you from running more than one TV from each cable box. You cannot even put an HDMI splitter in the line and feed the signal to two TV's. Obviously coax can carry all of the HD information since that is what is used from your antenna to your cable box. It is within the cable box that the signal is changed and fed to an HDMI output. On some cable boxes you do have an S-video and a component video output that you can use to feed a second TV but it will not be HD. On some smaller TV's you cannot notice much difference between HD and standard broadcast so it may not make any difference for you.
1. They DO make Component and HDMI splitters to run multiple TV's from 1 source. Tiffin has used the system for 4 years.
2. The COAX cannot transmit HD signal from a source. But CAN transmit the Over the Air local HD sugnal and you will get HD from over the air signals. There is NO Coax output on Sat HD boxes, only on Cable systems. On Cable systems with coax OUTPUT, that cannot transmit HD signal, just SD signal to the TV. Doug
I do have an HDMI splitter, which I have tried, and it will NOT allow two TV's to run off of a single satellite box. I can run one TV or the other, but not both at the same time. What I mentioned about coax being able to carry the HD signal is exactly as I said. My Winegard SK-3005 HD satellite antenna is connected to my DirecTV box by a single COAX cable, so obviously all of the HD information is being carried from my dish to my DirecTV box. It is changed within the DirecTV box so that the only outputs are Component, S-video(neither of which are HD, and a single HDMI output.
You are confusing INPUT from a source with OUTPUT. The Input from your roof Winegard is NOT HD but an electronic download signal to your Sat HD receiver that then converts that electronic signal to a HD video. That then MUST be transmitted in only 2 ways for true HD--Component or HDMI. As I stated, IF you want to spend he money you can buy Component and HDMI switching systems for multiple HD TV's from a single source. They are NOT cheap. Doug
nemo45
Arlington, WI
Posted: 11/21/11 08:04am Link  |  Print  |  Notify Moderator
Well that's not exactly true. We have a dishnetwork two TV DVR box and it does have a coax outlet. Otherwise how would you operate the 2nd TV off of it. And the TV in the back shows the strength and type of signal and it does show that some of the shows are at 720i.
Don Niemeyer
2006 Gulf Stream Tour Master T40A
2011 Chevy Equinox LT1 Toad
Clay L
Sioux Falls, South Dakota
Posted: 11/21/11 09:04am Link  |  Print  |  Notify Moderator
Many of the newer sat receivers do not have a coax output. My DirectTV HR24 receiver does not have one.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
rvrepairnut
bc
Posted: 11/21/11 09:11am Link  |  Print  |  Notify Moderator
yes u put a splitter system in so one HD box will supply any number of tv,s.My allegro bus comes from the factory with a HDMI splitter system and i have HD TV at all 4 tv,s.Now if u want different channels then us need seperate receivers.the difference on HD verses regular TV is very noteable
rvrepairnut
bc
Posted: 11/21/11 09:13am Link  |  Print  |  Notify Moderator
there is no need for coax out on new revceivers as most are HD and need 5 cable multi link or HD black cable or u can use the sv outlet etc
dougrainer
Carrolton, Texas
Posted: 11/21/11 10:02am Link  |  Print  |  Notify Moderator
NO , YOU are wrong. There is NO WAY to transmit HD in ANY form over COAX cable. Whatever and Whoever set up your system may have used COAX to the other TV, but it is NOT HD, regardless of what you think the TV display tells you. That said, that "Coax" may also transmit local antenna signals and your TV CAN process that. But regardless of ANY type system, COAX CANNOT transmit/transfer TRUE HD. PERIOD. Doug
TechWriter
On The Road
Posted: 11/21/11 11:13am Link  |  Print  |  Notify Moderator
Maybe with Direct, but my Dish 211k (a newer receiver) has HDMI, component, composite, and coax outputs. So you could connect 3 TVs to it if you wanted. Of course you'd all be watching the same thing.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
Tom N
Sarver, PA/Crystal River, FL/Shelocta, PA
Posted: 11/21/11 12:48pm Link  |  Print  |  Notify Moderator
You need a HDMI splitter such as the one pictured below.
HDMI 1x2 Mini Splitter, Full 1080p v1.3 for HDTV PS3 XBOX Blu-Ray DVD DirecTV
HDMI Distribution Amplifier (1x2)
Introduction:
The HDMI Distribution Amplifier (1X2) is a two outputs HDMI splitter
It distributes the HDMI input into two identical outputs.
These tow outputs are synchronized.
HDMI Distribution Amplifier (1X2) has the ability of buffering and amplifying
Series connection of it achieves long distance transmission of HDMI signal of more than 15 meters
When two or more them are cascaded,they can be used to create a larger distribution,it offers solutions for HDTV retail and show site
HDTV, STB, DVD and Projector factory, noise space and security concerns, data center control information distribution, conference room presentation school and corporate training environments.
meritline.com
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2012 Honda Accord EX-L · 2008 Honda Odyssey EX-L
texasrat
Las Crusas, NM USA
Posted: 11/21/11 07:03pm Link  |  Print  |  Notify Moderator
Interesting
My Meridian has a Winegard Traveler (Dish Network) and 2 VIP/211 receivers. The front 211 receiver is running (2) front TVs that are connected: 1) HDMI Cable 2) Component (RGB) plus R/W for sound and the outside TV which is also Component (RGB) + R/W. The rear 211/TV is connected via HDMI. ALL TVs are running HD (720P).
PHESPE
nemo45
Arlington, WI
Posted: 11/22/11 08:23am Link  |  Print  |  Notify Moderator
Introduction:
meritline.com
-Tom
So, what good would this be for RV use? Since it has identical outputs you'd have to watch the same program on both tvs. I'd much rather have the ability to watch different programming on each tv even though its not HD. This to me is one of the main reasons in having a tv in the bedroom. I cannot watch the same programming as the wife does. A fella can only take so much dancing with the stars.
