RV.Net Open Roads Forum: Fifth-Wheels: Broken Shock
 > Broken Shock
Elkhunter
Western Colorado
Posted: 11/23/11 09:43pm Link  |  Print  |  Notify Moderator
Are the shocks on a fvr the same as automotive shocks? What do I need to do to change one out? I was underneath the coach today while spraying the slide gears and noticed that I have a broken shock. How do I fix it?
Bill, Lisa, Ethan, Graycen and Whitney
2010 Dodge Ram 3500 Laramie Mega Cab Cummins Turbo Diesel (Loaded to the hilt)
2002 Cedar Creek 36RLTS Custom
thecampingman
Wilmington, OH, USA
Posted: 11/24/11 05:29am Link  |  Print  |  Notify Moderator
Spray the ends with WD-40 so by the time you get around to taking the nuts off they'll be loosened up.
Take off the good one and take it to an auto parts store and get the fattest one they sell with that much travel and the same mounts. Because if yours were factory installed they were the most minimal size that would fit.
Replace all of them. Give the WD-40 at least 24 hours to penetrate the rust before attempting removal.
That's what I would do.
Dave
'03 GMC 4500 Topkick with Duramax/Allison
'04 36' McKenzie Medallion triple slide
Cabover kayak racks w/18' touring kayaks.
Bicycle carrier on the front with a street bike & a mountain bike
Snowbird W/Ohio camper dock
spadoctor
Clinton Corners, NY
Posted: 11/24/11 05:48am Link  |  Print  |  Notify Moderator
most times there is a number stamped in the shocks upper dirt shield. This number can be crossreferenced by NAPA or other good parts stores
phillyg
Front Royal, VA
Posted: 11/24/11 06:00am Link  |  Print  |  Notify Moderator
Agree except use PB Blaster on the nuts instead of WD40.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
kirk37r
Millville, New Jersey
Posted: 11/24/11 07:20am Link  |  Print  |  Notify Moderator
If your 5er has A rubber equalizer instead of the steel one take the shocks off and throw them away. You can go to the Cedar Creek owners Club website and yo will see that A lot of us have done this with our Creeks. Forest River dosnt put them on most of the product line since 2010. Plus if you do replace them you need to be careful in getting A large bodied shock. It can really tear the sidewall of your tires up quick if it hits them while running down the road. When our tires were replaced under warranty it was suggested by the factory to remove the shocks. I did and have never looked back didnt effect the ride at all with them removed. Tires were replaced due to the shocks hittting the sidewalls and cutting them.
2013 Cedar Creek 38 FL
2003 GMC 3500 DRW 8.1 / Allison, 4:11 4x4
Reese 16K Hitch, Prodigy Brake controller
Carol, Kirk & Nicholas 4YO Grandson we are raising
CAUTION! Behind this Truck is A contagious Disease, NO KNOWN CURE!!!
Its Called Camping!!!!!!
mapguy
Puget Sound
Posted: 11/24/11 08:13am Link  |  Print  |  Notify Moderator
Get Monroe replacements. They are trailer specific with a larger bias in controlling the rebound action than a typical automotive shock.
You either have to cross-reference or determine the part number by dimensions.
I use this PAGE to id shocks - scroll down to the bottom. Click on the Monroe part number for dimensions.
Usually buy them at Stengel Brothers online as they seem more reliable IMO. Once you find a part number enter the number in the search box HERE.
All the dimension and cross-reference info is on the Monroe Commercial website below but you have to dig the right PDF files out -the first link is just easier IMO.
Monroe RV webpage
wcjeep
Tacoma, Wa
Posted: 11/24/11 09:30am Link  |  Print  |  Notify Moderator
Ditto, avoid wd 40
johntank
Oxford, Ms 38655 USA
Posted: 11/24/11 12:15pm Link  |  Print  |  Notify Moderator
I will agree with takeing one off and going to a good parts house like NAPA and have them do a cross-reference, then you can pick the one you want by quality or price. JMHO
oldbiker7
Western Colorado
Posted: 11/24/11 08:39pm Link  |  Print  |  Notify Moderator
You might want to try the Spring Works in Grand Junction - I have found them to be extremely knowledgeable when it comes to any type of trailer or vehicle suspension.
2013 GMC 3500 Duramax CCSB 4x4, B&W Patriot hitch
2013 Arctic Fox 27-5L
 > Broken Shock
