RV.Net Open Roads Forum: Class A Motorhomes: Loose dashboard
 > Loose dashboard
Don D.
Tracy, Ca, USA
Posted: 11/27/11 10:01am Link  |  Print  |  Notify Moderator
I know this is an old topic, but unable to locate it by doing a search. Does anyone have information on someone who can rebuild the dash to stop all the squeeks? I continue to redo the bolts under the hood but the fix only lasts for a short time. Thank you.
2004 Pace Arrow 35G
2001 Dodge Dakota Quadcab
SMI braking
HTT to be?
Southern Wisconsin
Posted: 11/27/11 10:57am Link  |  Print  |  Notify Moderator
are they screws or bolts??
If they are screws, remove them and fill the holes with a stong 2 part epoxy. Then after it dries, it should hold the screws tight.
If the are bolts, change the nuts to a locking style, or put a bead of loctite on the threads.
2007 Jayco 23B
2009 E350 Ford Club Wagon 5.4 w/ tow pkg
Equalizer hitch, Prodigy P3 brake controller
Buddy 125 Scooter-FUN!
1997 Coleman Sunridge- Served us well for 11 years!
Gjac
Milford, CT
Posted: 11/28/11 07:14am Link  |  Print  |  Notify Moderator
I added some brackets to each side of the dash and screwed them in place and it stopped the dash from vibrating.
Weathertodd221
FL
Posted: 11/27/11 01:43pm Link  |  Print  |  Notify Moderator
depending on your dash plate... you can get those felt pads at homedepot... then remove the affected panel areas and put the pads on the backside.
Usually squeaks are plastic to plastic friction.
Livin Good
On The Road
Posted: 11/27/11 03:18pm Link  |  Print  |  Notify Moderator
Use some aftermarket dashboard clips.
RVUSA
Orlando, FL, USA
Posted: 11/27/11 11:50am Link  |  Print  |  Notify Moderator
If you can tighten the screws so that it stops, then loosen them and squirt some silicone sealant in between the dash and the frame where the screws are. Let the sealant dry then re-tighten. Should last a lot longer with a bit of cushion in there.
michahicks
Waterford/Gaylord, Mi
Posted: 11/28/11 07:45am Link  |  Print  |  Notify Moderator
That's what's been making me crazy, the dashboard moving/jumping up and down. Not a lot, just enough to make me crazy. I added a post to better support the dash in the center. It seems much sturdier, but won't know for sure until the next run. Also removed the CRT TV and replaced it with an LCD. That removed quite a bit of weight from the dash, may make a difference as well.
1997 38' HR Endeavor, 275 Cat, Freightliner
2003 CR-V Toad, Blue Ox, Ready Brake
Livin Good
On The Road
Posted: 11/28/11 08:34am Link  |  Print  |  Notify Moderator
You can also purchase some aftermarket seat brackets when turned at an angle make excellant dash brackets. Make sure not to order the ones for electric seats.
Good luck....
 > Loose dashboard
