Amarillo6oh
Rockwell, NC
I'm looking for what works the best? I'm sure many have went through the ol trial by error and some setups werern't worth the******that was going through it. Thanks in advance!
2006 Ford F350 Amarillo: B&W Hitch, R4Tech Suspension, Garret Powermax Stage 1 Turbo, 5" MBRP Exhaust, Custom Tuned SCT X3
2008 Weekend Warrior CL4005 43'
Suzanne and Brad
Oregon
We purchased some gutters and use those to hold the sewer hose when hooked-up ~ easy, lightweight and inexpensive.
Happy Travels!
Suzanne & Brad
Old-Biscuit
Across the USA
What works the best......hummmmmmmmmm
Having someone else do the dumping.
Just what are you looking for.....'best'?
Best procedure? Dump a little grey 1st to test then dump black followed by remaining grey.
Best place to dump? At campsite, CG dump station, dump station on way home, at home
Best hose? I like ones that collapse and have fittings that turn independent of hose
Best connections? For sewer/90* elbow with multiple sized threads. For end of drain line/clear 45* elbow
vladen
Louisiana
Downhill works mostly better than uphill
Vlad's busy workings
All hope is gone
2oldman
Winchester WA
Can you be more specific, so we don't just all try to guess what it is you're getting at?
sunkatcher
Fulltimer
Amarillo6oh wrote: I'm looking for what works the best? I'm sure many have went through the ol trial by error and some setups werern't worth the******that was going through it. Thanks in advance!
Like everything about RVing It all depends. It depends on what type of Rving you do. Where you will be staying where you’re Rv will be parked. How you are going to use your Rig. Some here on the board will talk to you about different systems. Some use a macerator pump. Some electric, some not, some portable some permanent. They will talk about stinky slinky’s and eve troughs. The only thing I would tell you being new to this Rv thing is to not get cheap. If you are going to use the 3” hose that’s good but get the best that money will buy. If you go macerator, have it installed by someone that knows them.
Good luck and if you have specific questions don’t hesitate to ask.
Ron
masa4u.com
Amarillo6oh
Rockwell, NC
I meant hose, elbows, clear view. Im sure some are junky and some are better. Im looking for a nice quality setup, as I like to do it right the first time. I hate buying something to find out for a few bucks more, this would have worked better.
Is the macerator worth the money?
Thanks all.
2oldman
Winchester WA
Buy the best quality hose you can find. Macerators are more suited for dry camping.
old guy
Oregon (pronounced Or e gun)
hoses come in various thickness. get the heaviest weight or thickness you can find.
ArcticDodge
Sammamish, WA
The cheap ole hose I bought in 2000 is still in use today. Never thought my $&!# needed to travel in luxury on it's way to the hole in the ground.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400
1 Wife 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 23 years to retirement!!!!
