RV.Net Open Roads Forum: Truck Campers: Camper damage repair
 > Camper damage repair
clinthia
Flathead County, Montana
Posted: 11/28/11 06:34pm Link  |  Print  |  Notify Moderator
On our last trip the side of the camper base was damaged.
I am thinking of repairing the damage with diamond plating or something similar. just wondering if anyone has done this. Photos would be appreciated.
Clint
2007.5 Dodge 3500 4X4 Crewcab with 6.7 Cummins
2004 EC950 w/ slideout
2 Costco 6 volts
Yamaha EF1000IS
Kyocera solar panel
GO POWER 300 watt 12 volt PSW inverter
TorkLift tiedowns with Fastguns
Timbrens
Homemade bumpstops
The Schnauzers Madeline & Genevieve
Peg Leg
Anderson, IN
Posted: 11/28/11 10:27pm Link  |  Print  |  Notify Moderator
You can take a look at some pics where I cut mine out to fit over a gas tank. The cut out is near the end of my picture post.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24632796.cfm
You should be able to remove a section of that panel and check the framing for damage. Then box it back up. It doesn't look like that hard a fix to me.
Good luck.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
sundowners
suffolk UK
Posted: 11/29/11 02:53am Link  |  Print  |  Notify Moderator
Hi
just a bit curious how you damaged it ???-------I wouldn't use diamond -------I would use smooth ally and get it folded as big as possible, something like 2ft X 12'' X 12'' Or if you can, the full length of the side ???? about 2mm thick (sorry to mix metric and imp. !!!)--------diamond plate looks good and is tough, but it has a tendancy to catch if you dont allow plenty of clearance when putting camper on and off---IMHO-----I would screw and bond with Dicor or Sikaflex
Nigel & Pamala----Mildenhall
* This post was edited 11/29/11 03:19am by sundowners *
