RV.Net Open Roads Forum: Technology Corner: GPS Calculating 0%
 > GPS Calculating 0%
CARBONE
Salem, NH
Posted: 11/30/11 11:05am Link  |  Print  |  Notify Moderator
Hi All
Have a Garmin 2460 GPS, when I try to get a route It, comes up Calculating 0%, no mater by address, favorites, etc. any Ideas
Thanks
AL
exeter_acres
North of Atlanta, GA
Posted: 11/30/11 11:06am Link  |  Print  |  Notify Moderator
have you turned it off and back on?
mine every once and a while will just stop.. and I need to restart it.
CARBONE
Salem, NH
Posted: 11/30/11 11:10am Link  |  Print  |  Notify Moderator
Exter
Yes
exeter_acres
Posted: 11/30/11 11:35am Link  |  Print  |  Notify Moderator
found this on another forum
The solution is to hold the on-off switch for 30 seconds. It worked, once you know what to do in this situation. It looks like a common problem for the 1xxx, 2xxx and 3xxx series.
Have you plugged into your computer and done any software updates?
Not a Clue
Southern Ca
Posted: 11/30/11 01:39pm Link  |  Print  |  Notify Moderator
Might work to pull the battery out and put it back in to reboot.
* This post was edited 11/30/11 04:28pm by Not a Clue *
Linda B.
Our Blog
2009 29' Fleetwood, Fiesta V10 - The Little Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
FMCA# F412985
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
Nvr*lost
SW Ohio
Posted: 11/30/11 01:57pm Link  |  Print  |  Notify Moderator
CARBONE wrote:
Hi All
Thanks
AL
When my Garmin would not calculate a trip, "Help" said it needed to be recalibrated. The process was to turn it off, turn it back on, but hold it in the on position for 30 seconds and then follow directions that come up on the screen. After that, it worked fine.
Wadcutter
IL
Posted: 11/30/11 07:34pm Link  |  Print  |  Notify Moderator
Have you tried doing a hard reset?
IIRC for the 2460, with the unit off, hold the right lower corner of the screen while powering on. That will give you the hard reset screen.
Camped in every state but Alaska
CARBONE
Salem, NH
Posted: 12/01/11 05:40am Link  |  Print  |  Notify Moderator
Wadcutter
Can't hard reset, ??
brobox
Sunny SW. Florida
Posted: 12/01/11 07:56am Link  |  Print  |  Notify Moderator
X2 that has always worked for me.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
Wadcutter
IL
Posted: 12/01/11 07:26pm Link  |  Print  |  Notify Moderator
CARBONE wrote:
Wadcutter
It won't let you do a hard reset? Hmmmmm.
Try holding the upper left corner of the screen while turning it on. See if that will do it.
