RV.Net Open Roads Forum: Tow Vehicles: 2005 F350 Powerstroke tow questions
Search only in Tow Vehicles
 > 2005 F350 Powerstroke tow questions
ninemmbill
Henderson, NV
Posted: 11/30/11 06:17pm Link  |  Print  |  Notify Moderator
ib516 wrote:
Powerstroke experts: could it be stuck turbo vanes causing low boost = low power?
OP: Is there black smoke coming out the tailpipe when you're towing uphills?
It will boost well over 20. I believe it tops out about 28psi.
It runs clean out the exhaust, nothing visible.
shum02
Burlington ON CDA
Posted: 11/30/11 06:36pm Link  |  Print  |  Notify Moderator
I'm guessing you have the tranny in T/H? On a decent grade with T/H on I can easily see 3000rpms letting the truck do it's thing. I don't have the throttle mashed but I certainly don't mind the engine winding up, the 6.0 was built to spin, let it.
Music to my ears when she's working
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
Camping Pic's and Mods
Winter Camping Tips and Tricks
_Me2_
Fresno, CA
Posted: 11/30/11 07:09pm Link  |  Print  |  Notify Moderator
Sounds about right for stock with big tires. I'm far from stock now, so it pulls a bit harder. Being able to hold 50 up a steep grade is really not that bad.
2005 Ford F250 PSD Lariat CCLB 4x4, 6" Fabtech lift on 35s, airbags
2006 Rage'N Falcon 3405
jeffws
Ladera Ranch CA
Posted: 11/30/11 07:16pm Link  |  Print  |  Notify Moderator
28psi is about max on a stock 6.0 I normally run about 50-55 pulling grades but if I put my foot in it 3700 RPMs - EGT's at 1250 I can pull them at 65.......
00 FLHR
03 XR 50
05 CRF 70
03 XR 80
05 CRF 230F
06 Yamaha Rhino
06 KTM 525 EXC
05 F-250 CC,4X4,6.0 PSD
06 Gearbox 295FS
05 Carson 7x10
KD4UPL
Swoope, VA
Posted: 11/30/11 07:43pm Link  |  Print  |  Notify Moderator
I don't see how you can complain about not enough power and too slow up the hills if you still have throttle left. That's what the throttle is for, applying more power so it will go faster up hills. Seems like an easy fix to me, push down harder with your right foot, the truck should speed up. If it doesn't then you have a problem.
Seriously, your truck seems fine. The 6.0 makes it's power higher in the RPM band then a lot of other diesels.
45Ricochet
North Idaho
Posted: 11/30/11 09:33pm Link  |  Print  |  Notify Moderator
Wills250psd wrote:
I had two 6.0 psd around 3300 rpms is the sweet spot, push the pedal its OK.
Any RPM would be the sweet spot with a 6.
I certainly think your right foot needs some more exercise. Those motors love to rev, among other things.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Turtle n Peeps
California
Posted: 12/01/11 08:29am Link  |  Print  |  Notify Moderator
LOL, pretty much what I was thinking.
I don't understand peoples thinking when it comes to these things. Sort of like having an RV and not using the toilet. What is wrong with WOT? With my 6.5 I have been WOT for more than 15 minutes at a time and I bet a few times more than a 1/2 hour at a time.
As long as temps are within reason, open the thing up.
outside the fire"
