RV.Net Open Roads Forum: General RVing Issues: Thermostat and/or furnace problems
 > Thermostat and/or furnace problems
oldbeek
lancaster CA
Posted: 02/14/12 09:12pm Link  |  Print  |  Notify Moderator
BigSur2 wrote:
I'm thinking about installing a digital soon. So for you guys that have done it, is it easy to install or will I need some type of adaptor since the camper side is harnessed? Also, how will I then be able to control my fax speed. Most units only have settings for A/C or Heat......and fan ON or OFF. I may need to search this site for installation tips. Haven't done that yet.
Fan speed. wire high and low to the fan on terminal. Add a additional mini switch to the hi speed circuit. When switch is closed, fan is hi. switch open fan is low because hi circuit is disabled. I just wired mine hi all the time.
1994 27sl Alpenlite, 2001 Dodge Cummins auto 3.54 stock
BigSur2
Hampton, VA
Posted: 02/15/12 05:37am Link  |  Print  |  Notify Moderator
Where do you get this "mini switch" you're talking about?
BigSur2
2012 Keystone Bullet 286QBS
2006 Ford F150 5.4 V8
chipper
Nampa,Id
Posted: 02/15/12 05:29pm Link  |  Print  |  Notify Moderator
radio shack 275-264 $3.99
gene
langenc
Montmorency Co, MI
Posted: 02/15/12 10:14pm Link  |  Print  |  Notify Moderator
It sounds like you only have heat. Just get a thermofor heating-2 wire system. Talk to the guys at Lowes. I dont go to HomoDepot.
BigSur2
Hampton, VA
Posted: 02/16/12 05:27am Link  |  Print  |  Notify Moderator
Thanks. I will be trying this mod in the next few weeks.
tewall1
Summerfield, Florida
Posted: 02/16/12 01:15pm Link  |  Print  |  Notify Moderator
I had the same problem on an Atwood heater. It was a Bad board in the heater. $51 for a new Dinosaur board and $60 for the service call.
